So I finally got around to working on a dvd-order metadata agent.
This is for those tv shows that appear in a different order on the DVD than they were originally aired in. This agent should not be used as your primary agent for a section (unless of course you have a section consisting ONLY of stuff in dvd order).
Instead, use this agent on a per-series basis, using the "match using" setting.
Then the episode information is read in as:
That much was really easy. The part that I'm really proud of is the way it handles DVD-order episodes that consist of multiple Aired-Order episodes:
No guarantees that this won't crash, explode, or otherwise fail to perform as expected, so feel free to post bugs here.
Updated: now will work with episodes that don't have a DVD order set, like current seasons, or specials.
Right now, agents aren't able to have options. That's not too much of a problem for this-- you would just need a whole separate agent. But first I want to focus on getting this one to work with current seasons that don't have a dvd order.
Absolute ordering has a few twists to it that makes me think it's going to be trickier to get working. I think it would need some scanner modifications as well as an agent. I think I'll try to make one eventually (purely for the challenge, since I don't have anything in abs order myself) but I can't make any promises.
On the other hand, I think it might be a fairly straightforward modification, if the files were all had a false season number in there, just to make the scanner pick it up. But I would assume that that would be a less than ideal solution for end-users.
Firefly yes, and the Prisoner–and especially Farscape! (Glad to see that in your screen shot too!) This plugin did the trick for me. I’m following your progress on absolute order as well.
