Dyndns atv2 5.x plexconnect (pull request)
I have been able to get plexconnect to work outside of my network so I can take it anywhere and view my content without the need to bring anything but my atv2 on 5.2 untethered. So far I have been able to get it work on my appletv by altering some of the plexconnect files. I have pointed all the files within /assets/js to my dyndns by changing every instance of http://atv.plexconnect to http://mydns.whateveritis.com. I have my edited bag.plist and addsite within the folder /assets. I have added an app on my atv homescreen for outside my network for use with plexconnect/pms. The only files I have edited besides that are settings.cfg, webserver.py and plexconnect.py.
  1. Within plexconnect.py i changed the hostofplexconnect to mydns.whateveritis.com
  2. Here is a sample settings.cfg (without any new varibles for dyndns if need be):
    [PlexConnect]
    enable_webserver_ssl = False
    logpath = .
    enable_dnsserver = False
    prevent_atv_update = True
    port_dnsserver = 53
    enable_plexconnect_autodetect = True
    port_pms = 32400
    port_webserver = 80
    ip_plexconnect = 0.0.0.0
    certfile = ./assets/certificates/trailers.pem
    ip_dnsmaster = 8.8.8.8
    loglevel = Normal
    ip_pms = mydns.whateveritis.com
    enable_plexgdm = False
    port_ssl = 443
  3. And here is the addition to webserver.py needed as well, from what I can tell this doesnt effect anyone but addsite dyndns users post #37 shows where to add it into websever.py:
    # testing stuff – DJS
    if self.path.endswith(“bag.plist”):
    dprint(name, 1, “Serving bag.plist”)
    self.send_response(200)
    self.send_header(‘Content-type’, ‘application/xml’)
    self.end_headers()
    f = open(sys.path[0] + sep + “assets/bag.plist”, “r”)
    self.wfile.write(f.read())
    f.close()
    return
    if self.path.endswith(“addsite.mc”):
    dprint(name, 1, “Serving config profile”)
    self.end_headers()
    f = open(sys.path[0] + sep + “assets/addsite.mc”, “r”)
    f.close()
    return
    http://forums.plexapp.com/index.php/topic/81972-installing-a-new-app-on-appletv-without-hijacking-trailers/page-2
    So where im at at with this is wondering if a pull request can be generated by someone or someone else can work off of what I discovered and enable an easy way for dyndns into the plexconnect main github (I havent used github to much). Im always having to update some of the plexconnect files to fit my needs and was hoping there could be some variables put into place to enable dyndns into the setting.cfg file. Pay attention to where in setting.cfg & plexconnect.py the dyndns has no (http etc) prior which is important otherwise it will not work. There would I assume need to be a variable in settings.cfg for all the /assets/js files to change the all instances of http://atv.plexconnect to http://mydns.whateveritis.com but not any of the atv.plexconnect that had no (http etc) prior since it is not needed to run dyndns and would probably break dyndns/plexconnect (im constantly having to goto text edit and finding and replacing alot of code during every upgrade of the main plexconnect code to fix dyndns). Also if there could be a variable in setting.cfg to change the hostofplexconnect in plexconnect.py to mydns.whateveritis.com it would help as well. I would imagine this will come in handy if and when the atv3 is jailbroken as well. If there is a better way to do this im all for it just let me know. Maybe the new code in settings.cfg could be something like this:
    Dyndns=mydns.whateveritis.com
    Httpdyndns=http://mydns.whateveritis.com
    I hope I didn’t confuse you guys to much, looking forward to your feedback on this!
Writing with paragraphs and line breaks is comprehension tech.
I was able to simplify and get this to work if anyone wants of copy of my edited plexconnect that has variables for addsite to add a plexconnect app, I call it plexconnect on the go since you can use it anywhere you bring your atv it also does not require a plexconnect host with you if used remotely since you can point your atv to your dyndns or wan ip. I have submitted a pull request as well. For jailbroken atv2 only ios 5.1+ tethered or untethered, no IOS 6 or atv3 support yet since they have not been jailbroken, yet. You can use either a ip address (wan or local) or dyndns, the example I'm showing is using dyndns. This makes my plexconnect app added via addsite ALOT easier to manage when new plexconnect releases become available. There is a downloadable zip at the bottom that I will constantly update until this is merged with the main code. *download at bottom includes daemon bash support now from main branch for osx.
*Perquisites webserver, (dyndns or wan ip or local ip), port 80 forwarded to your plexconnect host (if used remotely, also may be a security risk according to f00b4r), port 32400 forwarded to your pms host. If you need help with any of this look in my signature here http://forums.plexapp.com/index.php/topic/80703-plex-media-server-plexconnect-startup-scripts-for-osx/ & goto http://portforward.com/ If you need to re-enable addsite here is a tut for that post #3 https://forums.plexapp.com/index.php/topic/80703-plex-media-server-plexconnect-startup-scripts-for-osx/?p=463856
1. Open terminal and navigate to /assets/js then copy and paste this command into your terminal:
sed -i '' 's/http:\/\/atv.plexconnect/http:\/\/192.168.1.101/g' *js
Note* This is a example you would need to change the 192.168.1.101 to whatever you want it to be dyndns/wan ip/local ip
If someone can fix that this is my pull request https://github.com/iBaa/PlexConnect/pull/192
I have also added a addsitefix app that would need to be edited in automator to fix this as well (attached below, if there is an error you did not edit it properly in automator)
2. Replace or edit the bag.plist in /assets
3. I have added a automated entry hostofplexconnect string in settings.cfg that you would put in yourdyndns.com
4. Put a plexconnect.png in /plexconnect (listed below)
5. Enter in your remote site ip into your home pms allow without auth like so as well as your home lan & wan ip's 10.10.10.10/255.255.255.0,11.11.11.11/255.255.255.0,192.168.1.101/255.255.255.0
Here is a sample settings.cfg for any hijacked app ie trailers, imovie, etc to work locally along with addsite added plexconnect app for a local or remote solution at the same time (dns on local atv's set to manual if they are atv3(s) or atv2(s) ios 6.x+, dns on remote jailbroken atv2(s) ios 5.1+ set to auto):
[PlexConnect]
port_pms = 32400
port_webserver = 80
hostofplexconnect = yourdyndns.com
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = yourdyndns.com
defaultjs = http://atv.plexconnect
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
port_dnsserver = 53
Here is a sample settings.cfg for a addsite added plexconnect app for a local or remote solution to allow trailers and every other app function as intended by apple while still having plexconnect work using its own app (dns on local and remote atv(s) set to auto if all they are atv2(s) ios 5.1+):
[PlexConnect]
port_pms = 32400
port_webserver = 80
loglevel = Normal
logpath = .
port_ssl = 443
port_dnsserver = 53
Only on ios 5.1+ atv2 jailbroken, post updated.
Settings.cfg updated on post #3 to allow plexconnect to work with trailers or any hijacked app at the same time with plexconnect added via addsite for a on the go solution. Enjoy :wink:
It was actually very easy to implement by changing these from false to true in settings.cfg:
I really hope they merge this with the main plexconnect code! I also seperated the settings.cfg examples in case you want trailers to function as intended by apple or any other hijacked app.
iOS pre 5.02 does not support the key in XML, as far as I can remember. I don't know what you did to confirm operation, but I don't think the Movie/Episode PrePlay Screens would work...
I had another user @stoffez use his jailbroken atv 5.02 to confirm. Can anyone else confirm this on atv2 ios 5.02?
Baa can you merge this with the main code? I submitted a pull request (link above).
This gets users to open up port 80 and opens the webserver to any man and his dog so it will not get merged due to security issues.
I dont see how its a security issue. Unless someone knows my bag.plist location and I have authorized them onto my pms, and they have a atv to see my content. I really doubt someone will go thru all that to see my pms content. People open port 80 all day to host websites.
Just by merging this on the main code doesnt mean anyone has to open port 80 on their router, that is completely optional.
If you do not understand why running a generically configured webserver and then opening port 80 on your router is a security risk then you have kind of proved my point.
Anyone running a webserver that is open to the outside world should make sure they are running a very locked down one and know what they are doing.
If this is in the main code and users see it as just another option then people will use it without realising the consequences, just like most of those users running their PC’s in a DMZ probably do not realise what they are doing.
Ya, I wrote this whole tutorial on how to do this but I have no idea about webservers, ok lol. What I meant was you need a lot to get to my content including a jailbroken atv2, bag.plist location, addsite enabled atv2 etc. You should be able to lock down a webserver hosting this easily if you know what you are doing, agreed. I hear ya some people dont get networking such as dmz etc, but this would be great as an option in plexconnect.
You can even do this locally as well without opening any ports to have a plexconnect app added via addsite, leaving all the appletv apps unhijacked & working as apple intended. Just because I use it anywhere in the world doesnt mean everyone has to. This is all optional by the user. I just hate always editing plexconnect everytime to get addsite to work, so I came up with this fix (pull request).
If you separated out the add site stuff from the remote stuff it would be good, it would be a lot easier to look at to see about if it was a good thing to add.
All of it is on the pull request seperated on the link above. Download a copy of mine and give it a try, its pretty sweet, at least i think :wink: here is my simplified forked copy of plexconnect (addsite enabled):
https://github.com/wahlmanj/PlexConnect
Can't we just run plexconnect on the atv and use the addsite to access it without hijacking any other apps.  This would allow for myplex and you to access your media from anywhere.  I am currently trying this method but having a hard time to get it to work.
Yes you can, its the settings.cfg option with atv dns set to auto post #3. If u get addsite working this tut will get u going the rest of the way. Webserver is required hosting plexconnect to get this addsite method (plexconnect app) to work locally or remotely.
I now have add site working.
If I want to point the plexconnect bag.plist file to my ATV dns plexconnect server what should it look like.  I do not want to use dyndns.  I don't feel this would be necessary now that we have myplex and I do not want access to my channels.
Just use your wan ip instead: http://www.whatsmyip.org/
All of this is on post #3
Say you webserver was located at your local ip address 192.168.1.101
You would type this in to addsite if this was where your bag.plist was located:
192.168.1.101:7777/sharedfolder/plexconnect/assets/bag.plist
Webserver tut is in my signature.
http://forums.plexapp.com/index.php/topic/80779-install-trailerspem-from-appletv-using-a-webserver-on-osx/
Instead of using your wan ip you can use your local ip as well.
So just to be clear you can use dyndns or wanip or local ip for all the variables in post #3 ALL REQUIRE A WEBSERVER NO MATTER WHAT! You can use your webserver locally or remotely port 80 is only forwarded using the remote method.
If you open it up to the world that is on you and may be a security risk as @f00b4r warned.
