I turned on “Early Access” on the plex app my Vizio v705-h3 everything seemed to be fine until I tried playing a subtitled anime file, the audio was garbled on the TV but played fine from the server computer, I disabled “Early Access” and the audio on the TV was fine again, the audio is listed in settings as “(OPUS 5.1)”
Just double checking if you might be able to get me that chipset info I mentioned. I’m pretty sure I can fix it, I just need to verify that first. Thanks!
