Easy instructions for adding PleXBMC to XBMC
Very new at this and can’t figure out how to get the plex plugin into XBMC
download the zip file. go into xbmc under add a video plugin. choose from zip file. select that file and your good to go. there is a readme file located within the zip file itself which walks you through the process.
It doesn't work properly on recent builds for me at any rate (pre-Eden). Is it supposed to?
philip
Looks work
http://www.NEWMEETS.INFO/avatar1.jpg
