100% agree! I’ve got an open issue tracking this here:
The tl;dr is that I’d love to be able to, but at the moment, webhooks from Plex don’t provide enough information about the library for us to do this. I’ve raised an issue internally with Plex though, so hopefully we’ll be able to do something about this soon
I had a question. Are you able to submit the mbids via the webhooks? Otherwise how does this work? Because listenbrainz requires the mbids does it not?
Unfortunately webhooks don’t provide MBIDs in the payload, they provide Plex GUIDs. As far as I’m aware, there’s no trivial way (or even any way at all, really) to map these GUIDs to an MBID. Thankfully ListenBrainz doesn’t require MBIDs, they’re an optional field. API docs can be found here:
It’s definitely something I’d like to be able to do one day though. In the interim, MetaBrainz have been working hard on linking un-matched data to MusicBrainz entities, and from what I’ve seen, this works pretty well!
That’s why features like their new “tracks you might like” work despite missing MBIDs in all the Plex submissions. If you haven’t already, you should check that feature out by the way!
Thanks for the link to the api doc. That was interesting. What exact fields are you able to send using the webhook method?
I’m imagining that if you are able to send for example the track number, identification on the MusicBrainz side would be quite a bit more reliable.
About ListenBrainz doing their own matching to mbids - okay, I’m new to ListenBrainz so I didn’t know this. But, I must say, I’m a bit confused about this. If ListenBrainz does some matching, how come the scrobbles from Plex is not showing up as clickable? As far as I’ve seen, users who scrobble with mbids have the artist/release/recording clickable.
This is not just cosmetic - ListenBrainz seem to separate artists with a featured second artist because of this. I mean that it sees “A feat. B” as a separate artists than “A”
This is the same problem last.fm has. I thought ListenBrainz could finally be a solution to this, but now I’m not sure. But maybe I’m misunderstanding something?
There’s a (surprising) amount to unpack in your questions, so let me try and answer as best I can!
ListenBrainz uses another MetaBrainz service called “MessyBrainz” to associate unlinked (messy) listens with an “MSID”, which is like a linking identifier. You can read more about it here:
So because a messy listen isn’t really linked to an mbid, you don’t see the links to the artist/recording, but they’re able to translate an msid to an mbid and provide recommendations for example.
The primary issue here is on the Plex side, not necessarily the last.fm or listenBrainz sides, and there’s actually two issues:
Plex doesn’t have any concept of track artist, only album artist
Plex only handles 1:1 artist relationships (with albums), so split EPs for example would be under a single artist named A and B, rather than under both A and B
As a workaround, handily in the webhook payload they send a text string that contains the track artist title. Unfortunately, this isn’t an actual artist entity (or list of artist entities), it’s just a string of text, so a feat. b is just one long string, not individual artists.
I’m suspecting the index in the payload above might actually be the track’s position on an album in Plex, so I might be able to send that as the trackNumber, but I’m not sure that would be wise. If users have missing tracks in albums, for example, the index may not be an accurate track number, and could actually make matching worse. IMO no data is better than bad data for this sort of thing.
Hopefully I’ve been able to answer your questions, and thanks for all the thought you’ve given it. I really appreciate the feedback and ideas!
Just used your eavesdrop website to get my listenbrainz set up. Very easy, very straight forward. So Far everything seems fine. Thanks for this fun and interesting project.
Thanks for the very in depth answer! I really appreciate that.
It’s a shame then that even after they match the messy info to a mbid that they don’t display it as such on the webpage. Kind of like an autocorrect of sorts. That is what threw me off.
About the limitations of Plex - wouldn’t it be enough if they could expose the recording mbid and the release mbid and you flat out just send that? Or am I misunderstanding now? I’m thinking if those two mbids are sent, ListenBrainz could bypass MessyBrainz entirely and just scrobble/display the info for that specific recording, even without any other specific information at all. I’m thinking that as long as that info is present, the specific track artist name or even id is not required.
In an ideal world, it would be great to be able to send MBIDs directly, agreed.
At this time though, MBIDs aren’t included in webhook payloads, so for now there’s not much we can do about it. I’ve requested the feature, but to my understanding it’s not currently on the roadmap. If Plex decides to implement this, you can be sure I’ll jump on it quickly and make the required changes for Eavesdrop.FM to take advantage of it
I’ve updated eavesdrop.fm today to take advantage of the new librarySectionTitle webhook payload field introduced in Plex Media Server 1.20.5.
During the setup flow, you’ll now (optionally) be able to exclude libraries from submitting data to ListenBrainz. This was requested primarily for users that have audiobook libraries using the Music library type. Simply add your library names to the exclusion list, separated by commas, and we’ll ignore any webhook events from these libraries. Make sure you’re using PMS 1.20.5 or later!
Check out today’s update. If you reconfigure your webhook now, you should be able to filter out the libraries you don’t wish to submit to ListenBrainz.
I just dumped last.fm for this + listenbrainz. Imported all my last.fm listens to listenbrainz, set up your webhook on my plex server, and verified it was sending my listens to listenbrainz. So far, it’s working great! Great job!
