Edit art for a searched title renders behind status bar
When looking at recent/random/etc from the library I am able to click the button at the top of the screen to edit art.
If I search a title instead, that same button is behind my status bar and cannot be interacted with.
A previous post about this by another user was closed without resolution and had using split screen as a workaround. I additionally found that in dev options for Android, I can change the notch options so that epps render beneath the cutout instead, but that is not ideal as it seems to break gesture navigation.
I don’t think it matters, but I am using a Pixel 7 on Android 13.
