Server Version#:1.18.9.2571
Hey all,
I’m a new user to Plex and have been trying to get Plex Server running on a RaspberryPi today. I’ve been successful in the install but kept running into general inconsistencies. After doing some digging I’ve found the cause of my problem… but I can’t figure out the root cause. One of 2 things breaks my build:
- I save a setting via the GUI and immediately my preferences.xml file is 0k.
- I restart the plexmediaserver service and my preferences.xml file reverts back to the default template.
Once the file starts saving a 0k, I’m lost. I can restore a saved copy but I’m guaranteed that #2 will come along and murder it on the next restart of the service or system.
It’s weird. Sometimes it works, sometimes it doesn’t. If it works sometimes, then I figure permissions are correct. My only guess at this point is a bad SD card. I don’t like that guess though.
Any direction you could provide would be greatly appreciated.
