Typically these issues happens when 2 minutes left to stream
The latest beta is better than previous, but still not 100%
Video, last 1.5 - 2 minutes of episodes gets caching/streaming issues, video pauses, skips seconds back/forth, eventually cut stream before finished. This seems to be more frequent if audio is AC3 (5.1)
Audio. On some streams, Video show good all the way, but audio can drop from 5.1 channel to 2. This also is most frequent at end of a stream, but not limited to. Can happen at any time. No it is not happening all the time, and does not happen at same point every time. Next time the same stream is running, it can be perfect, or worse
