After the new EPG was introduced (which is awesome btw) I’ve had issues with the channel icons, namely they do not show at all. Weirdly enough I remember seeing a few icons in the very bottom of the EPG in the first beta but since updating they’ve gone too.
I should say that I’m currently travelling and I’m playing remotely. As such I’ve noticed that posters are missing from time to time but eventually they show up. The EPG however consistently shows no icons at all.
I have attached detailed logs. The file shows one fresh start of the app, directly going to EPG and scrolling a bit. I’ve looked them through and noticed the GET command followed by an image resource which represents an icon. Sure enough they load if put in a browser. So the images are there on PMS.
I also completely deleted and reinstalled the app as I thought it might be a caching error, but alas no dice. Same thing.
This is what’s confusing me so you say accessing the URL works? Do you have a VPN connection established to your PMS location, or did you test while at home?
Ah yes stupid me. I do have a VPN connection that explains the browser part. However surely the PMS should produce resources that are available outside of home? As a reference this works fine on iOS and webapp . Why should the AppleTV app be different?
Another observation is that posters also work flawless on iOS but is lagging/not showing on AppleTV. My guess would be that they indeed share the code?
Yes it is accessible without a VPN. Other iOS devices show the icons regardless of VPN or not. I’m not sure if it caches icons but I confirmed this by killing the app.
Sorry to say that I didn’t get a chance to do this before I came home again. Plugging everything into my local network works as intended. Sorry I can’t help you more here. But something weird is going on.
