Server Version#: 1.43.0.10346 (1.42.2.10156, 1.42.2.10102)
Player Version#: 4.156.0 (…4.149.0)
Tuner Make/Model: Fritzbox 6690 Cable
Guide/Lineup name: NetCologne
Using XMLTV?:
Channel number/Name: any
Problem still open..
Server Version#: 1.42.2.10102
Player Version#: Plex web 4.149.0
Tuner Make/Model: FritzBox 6690
Guide/Lineup name: Netcologne
It’s not possible to match more than 159 channels in the EPG Channellist….
You can remove one and add another, but never get more than 159. (Tried to do a full matching list)
For the last 2 days, I have been having this nagging problem trying to setup a tv guide with more than 70 channels.
Only thing that worked for me was a brand new plex setup which I did as a test - completely starting over was not an option for me though.
Knowing a fresh instance worked perfectly fine told me something in my current setup was the problem.
a couple more hours I finally saw a parsing log with a massive URL. When Plex does this channel mapping, it makes a huge URL to map and submit all of the channels. If you are using a reverse proxy, it’s likely choking and causing a problem.
2 options that finally allowed me to map these channels:
login locally (192.168,* or whatever local IP you have plex running on) rather than through plex.tv or reverse proxy and then do the channel mapping there
Both solved this and can be done independently. I was stuck around 60 channels so your case is a bit different but, the problem sounds the same overall.
