EPG Settings
Hi all,
These questions are for the Roku.
Would anyone know how to set the EPG to retain the last channel watched? It would be nice to return to the guide and not have to page down from channel 1 to the 500’s where the HD channels are.
Also, this is a repeat, would anyone know how to set the remote buttons to last channel? It would be great to swap back and forth easier.
Thanks,
-Ron
I don’t have a Roku but I don’t believe what you’re asking about is available on the Roku.
If you have duplicate SD/HD channels, you can always disable the SD channels in the DVR settings. (Settings / Live TV & DVR and then under your tuner, click on “XX enabled” and then deselect channels to remove them from the EPG.
At least that way, you would be able to get to you HD channels quicker.
