Hi, sadly again there seems to be a issue with fetching EPG Data from xmltv source.
actually i cant tell exactly since when, but since a few releases my EPG Data is not updated anymore through the buildin scheduler …
also sadly the api trigger i used also doesnt work anymore to trigger it once /day but thats a different story ![]()
logs attached
as sample, daily updates should be done
as seen here its empty
manually triggering always works (nothing to change on source), as i use also tvheadend and other software its always updated there … epg is checked and up to date
after manual refresh
(File removed)
