Episodes view results in "There was an unexpected error loading this library"
Server Version#: 1.18.7.2438
I’m trying to view TV shows by episode in order to find dupes but I keep getting this error. Looking at the logs doesn’t reveal anything particularly telling:
Feb 23, 2020 12:11:24.963 [0x700006e3c000] ERROR - Unknown metadata type: folder
Feb 23, 2020 12:11:25.020 [0x700006e3c000] ERROR - Soci Exception handled: Cannot convert data to std::tm.
These occur when I choose TV shows by episode. The page has a retry button but it just loads the TV show names rather than the episodes. All other views appear to be working.
I have optimized the database, updated metadata and even rebuilt the database with no change to this. Does anyone have any other ideas?
Thanks.
Is this through Plex Web (web browser)? If so, what URL are you using? Does it work better/differently if you use https://app.plex.tv/desktop ?
It was on the web version, but I just tried the desktop version and it results in the same error… both on the client side and the server.
For completeness, I checked on the iPad version and it gives a slightly different error on the client side, “the active filter has no matches”. On the server it gives only the “Soci Exception”.
So after fighting this for several hours, I finally got to the bottom of this. The database that powers PMS is SQLite. For some reason it allows values in datetime columns that are not a valid date time or NULL. This is how you fix this issue.
1.) Stop Plex Media Server
2.) Download SQLite Browser @ https://sqlitebrowser.org/
3.) Open up your Plex DB on my linux machine it is under: Library/Application Support/Plex Media Server/Plug-in Support/Databases
4.) Export out all the tables as CSV to a folder
5.) Open up your favorite text editor and search for << , look for <<NULLSTR in datetime fields
6.) Note the table(s) and the IDS where that occurs
7.) Go back to SQLlite and open up a sql prompt
8.) for each instance of the NULLSTR delete it by doing
delete from where id = OF NULLSTR
Good luck!
I just tried that and I found no nulls. I noticed that there aren’t any datetime columns though, the “last_accessed_time_t” is a BIGINT and while it does allow nulls, querying both tables that have this column for null returns zero rows.
Any other thoughts?
