Error 4294967283 only with specific audio files
Plex Server Version 1.42.2.10156 for Windows
Plex Client Versions tested: 1.112.0.359-0d79a49f for Windows, 1.105.1.257-3bc35ab9 for Mac, Plexamp for Windows 4.12.3
Server:
Processor AMD Ryzen 7 7800X3D 8-Core Processor (4.20 GHz)
Installed RAM 64.0 GB (63.1 GB usable)
Graphics RTX 4070
Motherboard AM5 B650E
Media files streamed from Synology DS418 with current DSM version
All devices are wired ethernet
Random? music files produce this error in Plex client. The alert stops playback of the queue.
Plexamp skips the files and continues with the next file in the queue.
Plex info for a sample track (about a third of the files in this album produce the error and the rest play):
?xml version=“1.0” encoding=“UTF-8”?
MediaContainer size=“1” allowSync=“1” identifier=“com.plexapp.plugins.library” librarySectionID=“3” librarySectionTitle=“Music” librarySectionUUID=“e4ef02e8-3fa8-409b-9176-7f147af1b319” mediaTagPrefix=“/system/bundle/media/flags/” mediaTagVersion=“1758219494”
Track ratingKey=“271117” key=“/library/metadata/271117” parentRatingKey=“271116” grandparentRatingKey=“81392” guid=“local://271117” parentGuid=“local://271116” grandparentGuid=“plex://artist/5d07bbfc403c6402904a62fc” type=“track” title=“At Ch DeGaulle, Etc.” grandparentKey=“/library/metadata/81392” parentKey=“/library/metadata/271116” librarySectionTitle=“Music” librarySectionID=“3” librarySectionKey=“/library/sections/3” grandparentTitle=“Better Than Ezra” parentTitle=“Friction, Baby” originalTitle=“Better Than Ezra” summary=“” parentYear=“2001” thumb=“/library/metadata/271116/thumb/1735371971” parentThumb=“/library/metadata/271116/thumb/1735371971” duration=“40” addedAt=“1735371965” updatedAt=“1742860568”
Media id=“265663” duration=“40” bitrate=“899991” videoCodec=“mjpeg” container=“mjpeg” videoFrameRate=“PAL” hasVoiceActivity=“0”
Part accessible=“1” exists=“1” id=“277307” key=“/library/parts/277307/1742855123/file.mp3” duration=“40” file=“M:\Better Than Ezra\Friction, Baby\At Ch DeGaulle, Etc..mp3” size=“5198673” container=“mjpeg” deepAnalysisVersion=“6” requiredBandwidths=“7200,7200,7200,7200,7200,7200,7200,7200”
Stream id=“646043” streamType=“1” selected=“1” codec=“mjpeg” index=“0” bitrate=“899991” chromaLocation=“center” colorSpace=“bt470bg” frameRate=“25.000” refFrames=“1” requiredBandwidths=“7200,7200,7200,7200,7200,7200,7200,7200” displayTitle=“Unknown” extendedDisplayTitle=“Unknown”
/Stream
/Part
/Media
Image alt=“At Ch DeGaulle, Etc.” type=“coverPoster” url=“/library/metadata/271116/thumb/1735371971” /
Extras size=“0”
/Extras
Related
/Related
/Track
/MediaContainer>
MediaInfo tree view:
General
Complete name : \Media\music\Downloads\Better Than Ezra\Friction, Baby\At Ch DeGaulle, Etc..mp3
Format : MPEG Audio
File size : 4.96 MiB
Duration : 2 min 20 s
Overall bit rate mode : Constant
Overall bit rate : 256 kb/s
Title : At Ch DeGaulle, Etc.
Album : Friction, Baby
Performer : Better Than Ezra
Genre : Rock
Recorded date : 2001
BPM : 128
Cover : Yes / Yes / Yes / Yes
Cover type : Picture / Picture / Picture / Picture
Cover MIME : image/jpeg / image/jpeg / image/jpeg / image/jpeg
Comment : Rap Alternative
key : Em
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo / MS Stereo
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 38.281 FPS (1152 SPF)
Compression mode : Lossy
Replay gain : 0.69 dB
Replay gain peak : 0.381221
Stream size : 4.29 MiB (87%)
Min/Max : 000,182
Undo : +006,+006,N
The bitrate you emphasized was the one of the embedded cover art. Not that of the audio stream.
So, try the same file without the embedded cover art. See if it makes a difference.
Mp3Tag shows four cover images, all of which are image/jpeg still images. Every file in the album has the same four images embedded; only about a third of them throw the error. Is there anything I’m missing?
