Error after updating from 0.3 to 0.4
My Plexconnect was lagging sometimes while playing movies, so I decided to update it. I deleted the old one and decided to install the new one using git. I did it and generated new certificates. Now, when I try to access it from my ATV, I get this error:
01:40:58 PlexConnect: ***
01:40:58 PlexConnect: PlexConnect
01:40:58 PlexConnect: Press CTRL-C to shut down.
01:40:58 PlexConnect: started: 01:40:58
01:40:58 PlexConnect: Version: 0.4+
01:40:58 PlexConnect: Python: 2.7.8 (default, Jun 30 2014, 16:03:49) [MSC v.1500
 32 bit (Intel)]
01:40:58 PlexConnect: Host OS: win32
01:40:58 PlexConnect: IP_self: 192.168.25.3
01:40:58 DNSServer: started: 01:40:58
01:40:58 DNSServer: ***
01:40:58 DNSServer: DNSServer: Serving DNS on 192.168.25.3 port 53.
01:40:58 DNSServer: intercept: ['trailers.apple.com'] => 192.168.25.3
01:40:58 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
01:40:58 DNSServer: forward other to higher level DNS: 8.8.8.8
01:40:58 WebServer: started: 01:40:58
01:40:58 WebServer: ***
01:40:58 WebServer: WebServer: Serving HTTP on 192.168.25.3 port 80.
01:40:58 WebServer: WebServer: Serving HTTPS on 192.168.25.3 port 443.
01:41:32 DNSServer: DNS request received!
01:41:32 DNSServer: Source: ('192.168.25.6', 50544)
01:41:32 DNSServer: Domain: trailers.apple.com
01:41:32 DNSServer: ***intercept request
01:41:32 DNSServer: -> DNS response: 192.168.25.3
01:41:32 WebServer: serving .xml: /library/sections/5
Exception happened during processing of request from ('192.168.25.6', 64677)
Traceback (most recent call last):
  File "C:\Python27\lib\SocketServer.py", line 595, in process_request_thread
    self.finish_request(request, client_address)
  File "C:\Python27\lib\SocketServer.py", line 334, in finish_request
    self.RequestHandlerClass(request, client_address, self)
  File "C:\Python27\lib\SocketServer.py", line 651, in __init__
    self.handle()
  File "C:\Python27\lib\BaseHTTPServer.py", line 340, in handle
    self.handle_one_request()
  File "C:\Python27\lib\BaseHTTPServer.py", line 328, in handle_one_request
    method()
  File "C:\PlexConnect\WebServer.py", line 218, in do_GET
    XML = XMLConverter.XML_PMS2aTV(PMSaddress, self.path + query, options)
  File "C:\PlexConnect\XMLConverter.py", line 404, in XML_PMS2aTV
    PMS = PlexAPI.getXMLFromPMS(PMS_baseURL, path, options, authtoken=auth_token
  File "C:\PlexConnect\PlexAPI.py", line 350, in getXMLFromPMS
    response = urllib2.urlopen(request, timeout=20)
  File "C:\Python27\lib\urllib2.py", line 127, in urlopen
    return _opener.open(url, data, timeout)
  File "C:\Python27\lib\urllib2.py", line 396, in open
    protocol = req.get_type()
  File "C:\Python27\lib\urllib2.py", line 258, in get_type
    raise ValueError, "unknown url type: %s" % self.__original
ValueError: unknown url type: /library/sections/5
Exception happened during processing of request from ('192.168.25.6', 64678)
    self.handle()
    method()
Exception happened during processing of request from ('192.168.25.6', 64679)
    self.handle()
    method()
01:41:37 WebServer: serving .xml: /library/sections/5
Exception happened during processing of request from ('192.168.25.6', 64680)
    self.handle()
    method()
Exception happened during processing of request from ('192.168.25.6', 64681)
    self.handle()
    method()
Exception happened during processing of request from ('192.168.25.6', 64682)
    self.handle()
    method()
Does anyone has any idea on how to solve this?
Thanks!
exact same issue when using iMovie Theatre / iCloud.com as well:
Plex Connect will not open, have reset ATV, reinstalled Cert, Download fresh version of PlexConnect
Any ideas?
18:52:35 PlexConnect: ***
18:52:35 PlexConnect: PlexConnect
18:52:35 PlexConnect: Press CTRL-C to shut down.
18:52:35 PlexConnect: started: 18:52:35
18:52:35 PlexConnect: Version: 0.4+
18:52:35 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500
 64 bit (AMD64)]
18:52:35 PlexConnect: Host OS: win32
18:52:35 PlexConnect: IP_self: 192.168.0.3
18:52:35 DNSServer: started: 18:52:35
18:52:35 DNSServer: ***
18:52:35 DNSServer: DNSServer: Serving DNS on 192.168.0.3 port 53.
18:52:35 DNSServer: intercept: ['www.icloud.com'] => 192.168.0.3
18:52:35 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
18:52:35 DNSServer: forward other to higher level DNS: 8.8.8.8
18:52:35 WebServer: started: 18:52:35
18:52:35 WebServer: ***
18:52:35 WebServer: WebServer: Serving HTTP on 192.168.0.3 port 80.
18:52:35 WebServer: WebServer: Serving HTTPS on 192.168.0.3 port 443.
18:52:49 DNSServer: DNS request received!
18:52:49 DNSServer: Source: ('192.168.0.2', 62943)
18:52:49 DNSServer: Domain: init.itunes.apple.com
18:52:49 DNSServer: ***forward request
18:52:50 DNSServer: -> DNS response from higher level
18:52:50 DNSServer: DNS request received!
18:52:50 DNSServer: Source: ('192.168.0.2', 52348)
18:52:50 DNSServer: Domain: itunes.apple.com
18:52:50 DNSServer: ***forward request
18:52:51 DNSServer: -> DNS response from higher level
18:52:51 DNSServer: DNS request received!
18:52:51 DNSServer: Source: ('192.168.0.2', 57939)
18:52:51 DNSServer: Domain: xp.apple.com
18:52:51 DNSServer: ***forward request
18:52:51 DNSServer: Source: ('192.168.0.2', 51044)
18:52:51 DNSServer: Domain: www.google.com
18:52:52 DNSServer: -> DNS response from higher level
18:52:52 DNSServer: DNS request received!
18:52:52 DNSServer: Source: ('192.168.0.2', 58877)
18:52:52 DNSServer: Domain: e5153.a.akamaiedge.net
18:52:52 DNSServer: ***forward request
18:52:52 DNSServer: Source: ('192.168.0.2', 61208)
18:52:52 DNSServer: Domain: sr.symcd.com
18:52:53 DNSServer: DNS request received!
18:52:53 DNSServer: Source: ('192.168.0.2', 56607)
18:52:53 DNSServer: Domain: gdata.youtube.com
18:52:53 DNSServer: ***forward request
18:52:53 DNSServer: -> DNS response from higher level
18:52:54 DNSServer: DNS request received!
18:52:54 DNSServer: Source: ('192.168.0.2', 54979)
18:52:54 DNSServer: Domain: i.ytimg.com
18:52:54 DNSServer: ***forward request
18:52:54 DNSServer: -> DNS response from higher level
18:53:02 DNSServer: DNS request received!
18:53:02 DNSServer: Source: ('192.168.0.2', 55928)
18:53:02 DNSServer: Domain: s.mzstatic.com
18:53:02 DNSServer: ***forward request
18:53:02 DNSServer: -> DNS response from higher level
18:53:03 DNSServer: DNS request received!
18:53:03 DNSServer: Source: ('192.168.0.2', 55687)
18:53:03 DNSServer: Domain: sb.symcd.com
18:53:03 DNSServer: ***forward request
18:53:03 DNSServer: -> DNS response from higher level
18:53:05 DNSServer: DNS request received!
18:53:05 DNSServer: Source: ('192.168.0.2', 55043)
18:53:05 DNSServer: Domain: redirector.c.youtube.com
18:53:05 DNSServer: ***forward request
18:53:06 DNSServer: -> DNS response from higher level
18:53:06 DNSServer: DNS request received!
18:53:06 DNSServer: Source: ('192.168.0.2', 65506)
18:53:06 DNSServer: Domain: r4---sn-uo1-fabe.c.youtube.com
18:53:06 DNSServer: ***forward request
18:53:09 DNSServer: DNS request received!
18:53:09 DNSServer: Source: ('192.168.0.50', 60740)
18:53:09 DNSServer: Domain: www.icloud.com
18:53:09 DNSServer: ***intercept request
18:53:09 DNSServer: -> DNS response: 192.168.0.3
18:53:09 WebServer: serving /js/application.js
18:53:09 WebServer: serving .xml: /
Exception happened during processing of request from ('192.168.0.50', 49335)
  File "C:\Python27\lib\SocketServer.py", line 593, in process_request_thread
  File "C:\Python27\lib\SocketServer.py", line 649, in __init__
    self.handle()
    method()
  File "C:\PlexConnect\XMLConverter.py", line 376, in XML_PMS2aTV
    auth_token = g_ATVSettings.getSetting(UDID, 'myplex_auth')
AttributeError: 'NoneType' object has no attribute 'getSetting'
18:53:10 WebServer: serving .xml: /
Exception happened during processing of request from ('192.168.0.50', 49336)
    self.handle()
    method()
Exception happened during processing of request from ('192.168.0.50', 49337)
    self.handle()
    method()
18:53:10 WebServer: serving .xml: /PlexConnect.xml
18:53:10 XMLConverter: XML_ExpandNode - Error in cmd CUT, line
  File "C:\PlexConnect\XMLConverter.py", line 581, in XML_ExpandNode
    res = getattr(CommandCollection, 'TREE_'+cmd)(elem, child, src, srcXML, para
m)
  File "C:\PlexConnect\XMLConverter.py", line 878, in TREE_CUT
    key, leftover, dfltd = self.getKey(src, srcXML, param)
  File "C:\PlexConnect\XMLConverter.py", line 738, in getKey
    res = g_ATVSettings.getSetting(self.ATV_udid, attrib[1:])
18:53:10 XMLConverter: XML_ExpandLine - Error in {{URL(:/js/utils.js)}}
  File "C:\PlexConnect\XMLConverter.py", line 653, in XML_ExpandLine
    res = getattr(CommandCollection, 'ATTRIB_'+cmd)(src, srcXML, param)
  File "C:\PlexConnect\XMLConverter.py", line 1072, in ATTRIB_URL
    res = g_param['baseURL']  # base address to PlexConnect
KeyError: 'baseURL'
18:53:10 XMLConverter: XML_ExpandLine - Error in {{URL(:/PMS(owned)/library/sect
ions)}}
KeyError: 'baseURL'
18:53:10 XMLConverter: XML_ExpandLine - Error in {{URL(:/PMS(owned)/channels/all
KeyError: 'baseURL'
18:53:10 XMLConverter: XML_ExpandLine - Error in {{URL(:/PMS(shared)/library/sec
tions)}}
KeyError: 'baseURL'
18:53:10 XMLConverter: XML_ExpandLine - Error in {{URL(:/&PlexConnect=Settings)}
KeyError: 'baseURL'
18:53:13 DNSServer: DNS request received!
18:53:13 DNSServer: Source: ('192.168.0.2', 58449)
18:53:13 DNSServer: Domain: metrics.mzstatic.com
18:53:13 DNSServer: ***forward request
18:53:13 DNSServer: -> DNS response from higher level
18:53:13 DNSServer: Source: ('192.168.0.2', 64118)
18:53:13 DNSServer: Domain: e8218.ce.akamaiedge.net
18:54:06 DNSServer: DNS request received!
18:54:06 DNSServer: Source: ('192.168.0.2', 56492)
18:54:06 DNSServer: Domain: e905.a.akamaiedge.net
18:54:06 DNSServer: ***forward request
18:54:06 DNSServer: -> DNS response from higher level
18:54:07 DNSServer: DNS request received!
18:54:07 DNSServer: Source: ('192.168.0.2', 63636)
18:54:07 DNSServer: Domain: r1---sn-uo1-fabe.c.youtube.com
18:54:07 DNSServer: ***forward request
18:54:07 DNSServer: -> DNS response from higher level
18:54:14 DNSServer: DNS request received!
18:54:14 DNSServer: Source: ('192.168.0.2', 56474)
18:54:14 DNSServer: Domain: e5153.a.akamaiedge.net
18:54:14 DNSServer: ***forward request
18:54:14 DNSServer: -> DNS response from higher level
Did you restart PlexConnect after updating? Or stopped it while updating / restarted afterwards?
This looks to me like some files might still be old...
Several times. Also, I installed the new one in another folder.
Strange.
Double checking the logs...
First post: When starting PlexConnect, aTV was already running the trailers app (or old PlexConnect .js code). At that point PlexConnect didn't know about your aTV and stuff. And the JS code most probably wasn't compatible.
Second log: you switched to a different app... which shouldn't harm. Try rebooting your aTV to make sure the code is consistent. If the error persists, please set loglevel = High and attach the generated log file from PlexConnect startup to the first couple of errors.
Strange.
I rebooted the PC, and ATV still can't find Plexconnect.
Now the logs is
16:39:14 PlexConnect: ***
16:39:14 PlexConnect: PlexConnect
16:39:14 PlexConnect: Press CTRL-C to shut down.
16:39:14 PlexConnect: started: 16:39:14
16:39:14 PlexConnect: Version: 0.4+
16:39:14 PlexConnect: Python: 2.7.8 (default, Jun 30 2014, 16:03:49) [MSC v.1500
 32 bit (Intel)]
16:39:14 PlexConnect: Host OS: win32
16:39:14 PlexConnect: IP_self: 192.168.25.3
16:39:14 DNSServer: started: 16:39:14
16:39:14 DNSServer: ***
16:39:14 DNSServer: DNSServer: Serving DNS on 192.168.25.3 port 53.
16:39:14 DNSServer: intercept: ['trailers.apple.com'] => 192.168.25.3
16:39:14 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
16:39:14 DNSServer: forward other to higher level DNS: 8.8.8.8
16:39:15 WebServer: started: 16:39:15
16:39:15 WebServer: ***
16:39:15 WebServer: WebServer: Serving HTTP on 192.168.25.3 port 80.
16:39:15 WebServer: WebServer: Serving HTTPS on 192.168.25.3 port 443.
16:39:40 DNSServer: DNS request received!
16:39:40 DNSServer: Source: ('192.168.25.6', 53794)
16:39:40 DNSServer: Domain: trailers.apple.com
16:39:40 DNSServer: ***intercept request
16:39:40 DNSServer: -> DNS response: 192.168.25.3
One more update:
I rebooted all and regenerated the certificates
Plexconnect loaded at my ATV, though VERY slowly. It then started a movie, but when I tried forwarding it, it stopped and lost contact with Plex. Here's the log
16:56:44 WebServer: ***
16:56:44 WebServer: WebServer: Serving HTTP on 192.168.25.3 port 80.
16:56:44 WebServer: started: 16:56:44
16:56:44 WebServer: WebServer: Serving HTTPS on 192.168.25.3 port 443.
16:57:04 DNSServer: DNS request received!
16:57:04 DNSServer: Source: ('192.168.25.6', 57197)
16:57:04 DNSServer: Domain: trailers.apple.com
16:57:04 DNSServer: ***intercept request
16:57:04 DNSServer: -> DNS response: 192.168.25.3
16:58:53 DNSServer: DNS request received!
16:58:53 DNSServer: Source: ('192.168.25.6', 64655)
16:58:53 DNSServer: Domain: trailers.apple.com
16:58:53 DNSServer: ***intercept request
16:58:53 DNSServer: -> DNS response: 192.168.25.3
16:58:53 WebServer: serving *.cer: /trailers.cer
16:58:59 WebServer: serving /js/application.js
16:58:59 WebServer: serving .xml: /
16:58:59 ATVSettings: add section DY5JQ9M3DRHN
16:58:59 PlexAPI: ***
16:58:59 PlexAPI: looking up Plex Media Server
16:59:00 PlexAPI: GDM: Servers discovered: 1
16:59:00 PlexAPI: Servers (local+MyPlex): 1
16:59:00 WebServer: serving .xml: /PlexConnect.xml
16:59:00 WebServer: serving /js/utils.js
16:59:00 WebServer: serving .xml: /library/sections
16:59:15 WebServer: serving .xml: /channels/all
16:59:16 WebServer: serving .xml: /
16:59:17 WebServer: serving /js/utils.js
16:59:17 WebServer: serving /js/settings.js
16:59:20 PlexAPI: Error loading response XML from Plex Media Server
16:59:20 WebServer: serving /js/utils.js
16:59:21 WebServer: serving /js/sectionHoldSelect.js
16:59:26 WebServer: serving .xml: /
16:59:26 PlexAPI: ***
16:59:26 PlexAPI: looking up Plex Media Server
16:59:27 PlexAPI: GDM: Servers discovered: 1
16:59:27 PlexAPI: Servers (local+MyPlex): 1
16:59:27 WebServer: serving .xml: /
16:59:28 WebServer: serving .xml: /
16:59:28 PlexAPI: ***
16:59:28 PlexAPI: looking up Plex Media Server
16:59:29 PlexAPI: GDM: Servers discovered: 1
16:59:29 PlexAPI: Servers (local+MyPlex): 1
16:59:29 WebServer: serving .xml: /
16:59:32 WebServer: serving .xml: /
16:59:32 PlexAPI: ***
16:59:32 PlexAPI: looking up Plex Media Server
16:59:33 PlexAPI: GDM: Servers discovered: 1
16:59:33 PlexAPI: Servers (local+MyPlex): 1
16:59:33 WebServer: serving .xml: /
16:59:35 PlexAPI: Error loading response XML from Plex Media Server
16:59:40 WebServer: serving .xml: /
16:59:40 PlexAPI: ***
16:59:40 PlexAPI: looking up Plex Media Server
16:59:41 PlexAPI: GDM: Servers discovered: 1
16:59:41 PlexAPI: Servers (local+MyPlex): 1
16:59:41 WebServer: serving .xml: /
16:59:41 PlexAPI: ***
16:59:41 PlexAPI: looking up Plex Media Server
16:59:42 PlexAPI: GDM: Servers discovered: 1
16:59:42 PlexAPI: Servers (local+MyPlex): 1
16:59:42 WebServer: serving .xml: /
16:59:43 WebServer: serving .xml: /library/sections
16:59:55 PlexAPI: Error loading response XML from Plex Media Server
17:00:01 DNSServer: DNS request received!
17:00:01 DNSServer: Source: ('192.168.25.6', 56233)
17:00:01 DNSServer: Domain: trailers.apple.com
17:00:01 DNSServer: ***intercept request
17:00:01 DNSServer: -> DNS response: 192.168.25.3
17:00:01 WebServer: serving .xml: /channels/all
17:00:03 PlexAPI: Error loading response XML from Plex Media Server
17:00:03 WebServer: serving /js/utils.js
17:00:03 WebServer: serving /js/sectionHoldSelect.js
17:00:06 WebServer: serving .xml: /library/sections
17:00:11 WebServer: serving /js/application.js
17:00:11 WebServer: serving .xml: /
17:00:11 PlexAPI: ***
17:00:11 PlexAPI: looking up Plex Media Server
17:00:12 PlexAPI: GDM: Servers discovered: 1
17:00:12 PlexAPI: Servers (local+MyPlex): 1
17:00:12 WebServer: serving .xml: /PlexConnect.xml
17:00:12 WebServer: serving /js/utils.js
17:00:13 WebServer: serving .xml: /library/sections
17:00:15 PlexAPI: Error loading response XML from Plex Media Server
17:00:21 PlexAPI: Error loading response XML from Plex Media Server
17:00:26 PlexAPI: Error loading response XML from Plex Media Server
17:00:33 PlexAPI: Error loading response XML from Plex Media Server
17:00:41 PlexAPI: Error loading response XML from Plex Media Server
17:01:01 PlexAPI: Error loading response XML from Plex Media Server
17:01:13 DNSServer: DNS request received!
17:01:13 DNSServer: Source: ('192.168.25.6', 61058)
17:01:13 DNSServer: Domain: init.itunes.apple.com
17:01:13 DNSServer: ***forward request
17:01:13 DNSServer: -> DNS response from higher level
17:01:15 DNSServer: DNS request received!
17:01:15 DNSServer: Source: ('192.168.25.6', 52735)
17:01:15 DNSServer: Domain: bookkeeper.itunes.apple.com
17:01:15 DNSServer: ***forward request
17:01:15 DNSServer: -> DNS response from higher level
17:01:15 DNSServer: Source: ('192.168.25.6', 52731)
17:01:15 DNSServer: Domain: xp.apple.com
17:01:15 DNSServer: Source: ('192.168.25.6', 60141)
17:01:15 DNSServer: Domain: itunes.apple.com
17:01:24 DNSServer: DNS request received!
17:01:24 DNSServer: Source: ('192.168.25.6', 62246)
17:01:24 DNSServer: Domain: init-p01st.push.apple.com
17:01:24 DNSServer: ***forward request
17:01:24 DNSServer: -> DNS response from higher level
17:01:25 DNSServer: DNS request received!
17:01:25 DNSServer: Source: ('192.168.25.6', 63914)
17:01:25 DNSServer: Domain: 19-courier.push.apple.com
17:01:25 DNSServer: ***forward request
17:01:25 DNSServer: -> DNS response from higher level
17:01:29 DNSServer: DNS request received!
17:01:29 DNSServer: Source: ('192.168.25.6', 54207)
17:01:29 DNSServer: Domain: configuration.apple.com
17:01:29 DNSServer: ***forward request
17:01:29 DNSServer: -> DNS response from higher level
17:01:29 DNSServer: Source: ('192.168.25.6', 54403)
17:01:29 DNSServer: Domain: a4.mzstatic.com
17:01:30 DNSServer: -> DNS response from higher level
17:01:30 DNSServer: DNS request received!
17:01:30 DNSServer: Source: ('192.168.25.6', 53215)
17:01:30 DNSServer: Domain: a2.mzstatic.com
17:01:30 DNSServer: ***forward request
17:01:31 DNSServer: -> DNS response from higher level
17:01:31 DNSServer: DNS request received!
17:01:31 DNSServer: Source: ('192.168.25.6', 59350)
17:01:31 DNSServer: Domain: a5.mzstatic.com
17:01:31 DNSServer: ***forward request
17:01:31 DNSServer: Source: ('192.168.25.6', 50380)
17:01:31 DNSServer: Domain: a1.mzstatic.com
17:01:31 DNSServer: Source: ('192.168.25.6', 50009)
17:01:31 DNSServer: Domain: a3.mzstatic.com
17:01:32 DNSServer: -> DNS response from higher level
17:01:32 DNSServer: DNS request received!
17:01:32 DNSServer: Source: ('192.168.25.6', 50380)
17:01:32 DNSServer: Domain: a1.mzstatic.com
17:01:32 DNSServer: ***forward request
17:01:37 DNSServer: DNS request received!
17:01:37 DNSServer: Source: ('192.168.25.6', 50009)
17:01:37 DNSServer: Domain: a3.mzstatic.com
17:01:37 DNSServer: ***forward request
17:01:37 DNSServer: -> DNS response from higher level
17:01:37 DNSServer: Source: ('192.168.25.6', 54213)
17:01:37 DNSServer: Domain: trailers.apple.com
17:01:37 DNSServer: ***intercept request
17:01:37 DNSServer: -> DNS response: 192.168.25.3
17:01:37 DNSServer: Source: ('192.168.25.6', 50651)
17:01:37 DNSServer: Domain: init.ess.apple.com
17:01:37 WebServer: serving /js/application.js
17:01:37 WebServer: serving .xml: /
17:01:37 PlexAPI: ***
17:01:37 PlexAPI: looking up Plex Media Server
17:01:38 PlexAPI: GDM: Servers discovered: 1
17:01:38 PlexAPI: Servers (local+MyPlex): 1
17:01:38 WebServer: serving .xml: /PlexConnect.xml
17:01:38 WebServer: serving /js/utils.js
17:01:38 WebServer: serving .xml: /library/sections
17:01:42 DNSServer: Warning: DNS error (10054): An existing connection was forci
bly closed by the remote host
17:01:42 DNSServer: DNS request received!
17:01:42 DNSServer: Source: ('192.168.25.6', 54283)
17:01:42 DNSServer: Domain: sd.symcb.com
17:01:42 DNSServer: ***forward request
17:01:42 DNSServer: -> DNS response from higher level
17:01:42 D1NSServer: Source: ('192.168.25.6', 54283)7:01:42
 1W7:01:42ebServer: serving /js/utils.js
17:01:42 WebServer: serving /js/sectionHoldSelect.js
17:01:43 WebServer: serving .xml: /library/sections/5/recentlyAdded
17:01:47 DNSServer: DNS request received!
17:01:47 DNSServer: Source: ('192.168.25.6', 54283)
17:01:47 DNSServer: Domain: sd.symcb.com
17:01:47 DNSServer: ***forward request
17:01:47 DNSServer: -> DNS response from higher level
17:01:47 DNSServer: Warning: DNS error (10054): An existing connection was forci
17:01:47 WebServer: serving .xml: /
17:01:47 WebServer: serving /js/utils.js
17:01:47 WebServer: serving /js/settings.js
17:01:48 WebServer: serving *.jpg: /thumbnails/PlexConnectLogo.jpg
17:01:50 WebServer: serving .xml: /library/sections
17:01:50 WebServer: serving /js/utils.js
17:01:50 WebServer: serving /js/sectionHoldSelect.js
17:01:51 WebServer: serving .xml: /library/sections/5/recentlyAdded
17:01:52 WebServer: serving .xml: /library/sections/5
17:01:52 WebServer: serving /js/utils.js
17:01:52 WebServer: serving /js/updateXML.js
17:01:53 WebServer: serving .xml: /library/sections/5
17:01:54 WebServer: serving /js/utils.js
17:01:54 WebServer: serving /js/updateXML.js
17:01:54 WebServer: serving /js/settings.js
17:01:57 WebServer: serving .xml: /library/metadata/3925
17:01:59 DNSServer: DNS request received!
17:01:59 DNSServer: Source: ('192.168.25.6', 49969)
17:01:59 DNSServer: Domain: pancake.apple.com
17:01:59 DNSServer: ***forward request
17:01:59 DNSServer: -> DNS response from higher level
17:02:40 DNSServer: DNS request received!
17:02:40 DNSServer: Source: ('192.168.25.6', 53028)
17:02:40 DNSServer: Domain: trailers.apple.com
17:02:40 DNSServer: ***intercept request
17:02:40 DNSServer: -> DNS response: 192.168.25.3
17:02:41 WebServer: serving .xml: /library/sections/5
17:02:46 WebServer: serving /js/utils.js
17:02:46 WebServer: serving /js/updateXML.js
17:02:46 WebServer: serving .xml: /library/sections/5
17:02:47 WebServer: serving /js/utils.js
17:02:47 WebServer: serving /js/updateXML.js
17:02:47 WebServer: serving /js/settings.js
17:02:52 WebServer: serving .xml: /library/metadata/3940
17:02:53 XMLConverter: XML_ExpandNode - Error in cmd COPY, line
File “C:\PlexConnect\XMLConverter.py”, line 581, in XML_ExpandNode
res = getattr(CommandCollection, ‘TREE_’+cmd)(elem, child, src, srcXML, para
m)
File “C:\PlexConnect\XMLConverter.py”, line 852, in TREE_COPY
for elemSRC in src.findall(tag):
AttributeError: ‘NoneType’ object has no attribute ‘findall’
17:02:53 WebServer: serving /js/utils.js
17:02:54 WebServer: serving /js/selectAudioAndSubs.js
17:02:55 WebServer: serving .xml: /library/metadata/3940
17:03:07 WebServer: serving .xml: /library/metadata/3940
17:03:07 WebServer: serving /js/utils.js
17:03:07 WebServer: serving /js/selectAudioAndSubs.js
17:03:10 WebServer: serving .xml: /library/sections/5
17:03:10 WebServer: serving /js/utils.js
17:03:10 WebServer: serving /js/updateXML.js
17:03:11 WebServer: serving /js/utils.js
17:03:11 WebServer: serving /js/updateXML.js
17:03:11 WebServer: serving /js/settings.js
17:03:15 WebServer: serving .xml: /library/metadata/3925
17:03:15 WebServer: serving /js/utils.js
17:03:15 WebServer: serving /js/selectAudioAndSubs.js
17:03:17 WebServer: serving .xml: /library/metadata/3925
17:03:44 DNSServer: DNS request received!
17:03:44 DNSServer: Source: (‘192.168.25.6’, 49416)
17:03:44 DNSServer: Domain: trailers.apple.com
17:03:44 DNSServer: ***intercept request
17:03:44 DNSServer: -> DNS response: 192.168.25.3
17:04:52 DNSServer: DNS request received!
17:04:52 DNSServer: Source: (‘192.168.25.6’, 51627)
17:04:52 DNSServer: Domain: trailers.apple.com
17:04:52 DNSServer: ***intercept request
17:04:52 DNSServer: -> DNS response: 192.168.25.3
17:04:53 WebServer: serving .xml: /library/metadata/3925
17:05:01 WebServer: serving .xml: /library/sections/5
17:05:06 WebServer: serving .xml: /library/sections/5
17:05:13 PlexAPI: Error loading response XML from Plex Media Server
17:05:21 PlexAPI: Error loading response XML from Plex Media Server
17:05:26 PlexAPI: Error loading response XML from Plex Media Server
17:05:32 WebServer: serving .xml: /library/sections/5
17:05:52 PlexAPI: Error loading response XML from Plex Media Server
I'm out of ideas here, only thing I can think of is downgrading it.
a - it's not loglevel=High
b - it's not a log file attached
Hm... https://forums.plex.tv/topic/86012-how-to-use-imovie-theater-instead-of-the-trailers-app/?p=703375
Do you run beta iOS on your aTV?
