PlexConnect no longer working :(
Hi all,
So I messed up my PlexConnect somehow perhaps trying to install a channel? It was working flawlessly before I installed the channel and then after installing the channel it would not run on my ATV. It started off with really slow loading and "accessing trailers" but I could see the PlexConnect menu (Library, Channels, Settings) in the background but it would load extremely slow. I tried to reinstall PMS and PlexConnect but it still won't load up. Also, before I reinstalled it PlexConnect said "Exception happened during processing of request from..."
Please help! I'm stumped!
Thanks everyone! (And sorry in advance for not posting the pastebin log properly)
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3 - 6.0.1
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.40
  • The device and operating system (including version number) that PlexConnect is installed on: Windows 7 64-bit
  • The local IP address of the device that PlexConnect is installed on: 192.168.1.40
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows 7 64-bit
  • The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.8.10.215
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.40
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. I'm not sure how to check this one but I just downloaded the one off github>ibaa>plexconnect on 11/25/2013
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
                  [PlexConnect]
enable_webserver_ssl = True
logpath = .
enable_dnsserver = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = C:\PlexConnect-master\assets\certificates railers.pem
ip_dnsmaster = 8.8.8.8
loglevel = High
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
  1. 02:36:42 PlexConnect: started: 02:36:42
  2. 02:36:42 Settings: getsetting enable_plexconnect_autodetect=True
  3. 02:36:42 PlexConnect: IP_self: 192.168.1.40
  4. 02:36:42 Settings: getsetting enable_dnsserver=True
  5. 02:36:42 Settings: getsetting enable_webserver_ssl=True
  6. 02:36:42 DNSServer: started: 02:36:42
  7. 02:36:42 Settings: getsetting port_dnsserver=53
  8. 02:36:42 Settings: getsetting ip_dnsmaster=8.8.8.8
  9. 02:36:42 Settings: getsetting prevent_atv_update=True
  10. 02:36:42 DNSServer: ***
  11. 02:36:42 DNSServer: DNSServer: Serving DNS on 192.168.1.40 port 53.
  12. 02:36:42 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.40
  13. 02:36:42 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
  14. 02:36:42 DNSServer: forward other to higher level DNS: 8.8.8.8
  15. 02:36:42 DNSServer: ***
  16. 02:36:42 WebServer: started: 02:36:42
  17. 02:36:42 Settings: getsetting port_webserver=80
  18. 02:36:42 WebServer: ***
  19. 02:36:42 WebServer: WebServer: Serving HTTP on 192.168.1.40 port 80.
  20. 02:36:42 WebServer: ***
  21. 02:36:42 ATVSettings: init class CATVSettings
  22. 02:36:42 ATVSettings: load settings
  23. 02:36:42 Settings: getsetting enable_plexgdm=True
  24. 02:36:42 PlexAPI: ***
  25. 02:36:42 PlexAPI: looking up Plex Media Server
  26. 02:36:42 PlexAPI: ***
  27. 02:36:42 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
  28. 02:36:42 PlexAPI: Received data from ('192.168.1.40', 32414)
  29. 02:36:42 PlexAPI: Data received:
  30.  HTTP/1.0 200 OK
  31.
  32. Content-Type: plex/media-server
  33.
  34. Resource-Identifier: ca709d936de5fb61a5bd54bbe1580baf76284353
  35.
  36. Name: Kevin-Phi
  37.
  38. Port: 32400
  39.
  40. Updated-At: 1385374923
  41.
  42. Version: 0.9.8.10.215-020456b
  43.
  44.
  45.
  46.
  47. 02:36:42 WebServer: started: 02:36:42
  48. 02:36:42 Settings: getsetting port_ssl=443
  49. 02:36:42 Settings: getsetting certfile=C:\PlexConnect-master\assets\certificates railers.pem
  50. 02:36:42 Settings: getsetting certfile=C:\PlexConnect-master\assets\certificates railers.pem
  51. 02:36:42 WebServer: ***
  52. 02:36:42 WebServer: WebServer: Serving HTTPS on 192.168.1.40 port 443.
  53. 02:36:42 WebServer: ***
  54. 02:36:43 PlexAPI: servers discovered: 1
  55. 02:36:43 PlexAPI: Kevin-Phi 192.168.1.40:32400
  56. 02:36:43 XMLConverter: PlexGDM - PMS: 192.168.1.40:32400
  57. 02:36:43 ATVSettings: setOption: update pms_uuid to ('ca709d936de5fb61a5bd54bbe1580baf76284353',)
  58. 02:36:45 DNSServer: DNS request received!
  59. 02:36:45 DNSServer: Source: ('192.168.1.108', 53718)
  60. 02:36:45 DNSServer: Domain: p21-buy.itunes.apple.com.akadns.net
  61. 02:36:45 DNSServer: ***forward request
  62. 02:36:45 DNSServer: -> DNS response from higher level
  63. 02:36:46 DNSServer: DNS request received!
  64. 02:36:46 DNSServer: Source: ('192.168.1.108', 53718)
  65. 02:36:46 DNSServer: Domain: p21-buy.itunes.apple.com.akadns.net
  66. 02:36:46 DNSServer: ***forward request
  67. 02:36:46 DNSServer: -> DNS response from higher level
  68. 02:36:50 DNSServer: DNS request received!
  69. 02:36:50 DNSServer: Source: ('192.168.1.108', 60251)
  70. 02:36:50 DNSServer: Domain: trailers.apple.com
  71. 02:36:50 DNSServer: ***intercept request
  72. 02:36:50 DNSServer: -> DNS response: 192.168.1.40
This "log" is not from the latest sources. Did you download an ealier "release"?
Grab the latest, delete your ATVSettings.cfg file and try again...
Thanks for the quick response Baa! I had an earlier release of plexconnect that was downloaded on 10/28/2013 but it started doing really odd things like loading "accessing trailers" but showing the Plex interface so I decided to reinstall/update by downloading the latest. Apparently I didn't do that properly so I will try again as soon as I get home! Should I just do a clean/fresh install by deleting the whole PlexConnect-master folder (excluding the certificates folder) and redownloading?
Thanks again for your help!
Alright Baa here is the latest! I deleted the entire folder except the certificates folder and tried to reinstall that way. I'm no longer getting "Accessing Trailers" but instead "Trailers is unavailable.."
Here's the log:
  1. 16:33:44 PlexConnect: started: 16:33:44
  2. 16:33:44 Settings: getsetting enable_plexconnect_autodetect=True
  3. 16:33:44 PlexConnect: IP_self: 192.168.1.40
  4. 16:33:44 Settings: getsetting hosttointercept=trailers.apple.com
  5. 16:33:44 Settings: getsetting enable_dnsserver=True
  6. 16:33:44 Settings: getsetting enable_webserver_ssl=True
  7. 16:33:44 DNSServer: started: 16:33:44
  8. 16:33:44 Settings: getsetting port_dnsserver=53
  9. 16:33:44 Settings: getsetting ip_dnsmaster=8.8.8.8
  10. 16:33:44 Settings: getsetting prevent_atv_update=True
  11. 16:33:44 DNSServer: ***
  12. 16:33:44 DNSServer: DNSServer: Serving DNS on 192.168.1.40 port 53.
  13. 16:33:44 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.40
  14. 16:33:44 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
  15. 16:33:44 DNSServer: forward other to higher level DNS: 8.8.8.8
  16. 16:33:44 DNSServer: ***
  17. 16:33:44 WebServer: started: 16:33:44
  18. 16:33:44 Settings: getsetting port_webserver=80
  19. 16:33:44 WebServer: ***
  20. 16:33:44 WebServer: WebServer: Serving HTTP on 192.168.1.40 port 80.
  21. 16:33:44 WebServer: ***
  22. 16:33:44 ATVSettings: init class CATVSettings
  23. 16:33:44 ATVSettings: load settings
  24. 16:33:44 WebServer: started: 16:33:44
  25. 16:33:44 Settings: getsetting port_ssl=443
  26. 16:33:44 Settings: getsetting certfile=./assets/certificates/trailers.pem
  27. 16:33:44 Settings: getsetting certfile=./assets/certificates/trailers.pem
  28. 16:33:44 WebServer: ***
  29. 16:33:44 WebServer: WebServer: Serving HTTPS on 192.168.1.40 port 443.
  30. 16:33:44 WebServer: ***
  31. 16:33:57 DNSServer: DNS request received!
  32. 16:33:57 DNSServer: Source: ('192.168.1.126', 49665)
  33. 16:33:57 DNSServer: Domain: init-p01st.push.apple.com
  34. 16:33:57 DNSServer: ***forward request
  35. 16:33:57 DNSServer: -> DNS response from higher level
  36. 16:33:57 DNSServer: DNS request received!
  37. 16:33:57 DNSServer: Source: ('192.168.1.126', 49198)
  38. 16:33:57 DNSServer: Domain: 5-courier.push.apple.com
  39. 16:33:57 DNSServer: ***forward request
  40. 16:33:57 DNSServer: -> DNS response from higher level
  41. 16:35:15 DNSServer: DNS request received!
  42. 16:35:15 DNSServer: Source: ('192.168.1.108', 55922)
  43. 16:35:15 DNSServer: Domain: trailers.apple.com
  44. 16:35:15 DNSServer: ***intercept request
  45. 16:35:15 DNSServer: -> DNS response: 192.168.1.40
  46. 16:35:18 DNSServer: DNS request received!
  47. 16:35:18 DNSServer: Source: ('192.168.1.108', 58584)
  48. 16:35:18 DNSServer: Domain: p21-buy.itunes.apple.com.akadns.net
  49. 16:35:18 DNSServer: ***forward request
  50. 16:35:18 DNSServer: -> DNS response from higher level
  51. 16:35:23 PlexConnect: Shutting down.
  52. 16:35:24 WebServer: Shutting down.
  53. 16:35:24 WebServer: Shutting down.
  54. 16:35:24 ATVSettings: save settings
  55. 16:35:28 DNSServer: Shutting down.
  56. 16:35:28 PlexConnect: shutdown
SOLVED!
I don't quite know what the original issue was (the laggy browsing) but the reinstall failed to work because I created a new trailers.pem and I guess that when you make a new one it is unique and therefore didn't match with the certificate/profile installed on the ATV! I deleted all certificates from the certificate store and installed one (in order to make sure I could match them) and installed a profile using that specific certificate on the ATV. Now it's back up and running!
Thanks Baa! I hope this helps anyone else who might be confused!
correct.
