Error issuing curl_easy_perform(handle) 28
I have been using plex for some time on windows where it works normally, the server is installed and I even can browse it from my fire stick tv attached to the tv.
Then I decided to install Linux Ubuntu 19 on an old Acer Revo 70 (not so old, it previously ran on windows 10) because I thought It could be more reactive (I was wrong anyway).
In installed plex both with the package from the site and from the software center.
The result is always the same, I’m never able to claim the server,I always get errors.
I’m attaching the log, because I see different errors after the one above (error issuing curl_easy_perform(handle) 28).
If I access to plex.tv I never see the server on my account.
The same when I open the plex app on my fire stick.
The server is never showed. In fact, when I go to Settings ->General it says “This server is unclaimed and not secure. Claiming this server will associate it with your Plex account”.
Any help is appreciated.
FedericoPlex Media Server.log (188.5 KB)
Have you tried this article?
this has nothing to do with the common error, I have had this error for so long and I dont know it it is attributing to anything.
the attached article is citing a error 60, ours is a 28, it is actually different
However I do not believe this error actually causes issues as I have had it for years and nobody has stated an issue or that I can track down to this.
The AMD E-450 APU (CPU) is profoundly below the minimum required Passmark rating of 700 for PMS to run correctly.
This is the root cause of the timeout messages. The CPU is too slow.
The E-450 is rated at 409
It first appeared on the performance charts in 2011.
The best recommendation here is to get a newer / better CPU.
This CPU will not run Plex.
This is my CPU and I get this error on startup and periodically in the logs
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E3-1505M+v5+%40+2.80GHz&id=2637
Apr 24, 2020 02:42:06.605 [13796] INFO - Plex Media Server v1.19.1.2701-6327e27bf - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
Apr 24, 2020 02:42:06.605 [13796] INFO - Windows version: 10.0 (Build 18363), language en-US
Apr 24, 2020 02:42:06.605 [13796] INFO - 8 2712 MHz processor(s): Architecture=0, Level=6, Revision=24067 Processor Identifier=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
Apr 24, 2020 02:42:06.766 [3732] ERROR - SetForegroundWindow failed: 0x0
Apr 24, 2020 02:42:06.801 [10472] INFO - OCSP: Successfully retrieved response from cache.
Apr 24, 2020 02:42:10.312 [2964] INFO - AutoUpdate: no updates available
Apr 24, 2020 02:42:11.793 [9740] WARN - Sync: sync list 32667593 belonging to user 1 (Mini_Server) has died of old age, ignoring
Apr 24, 2020 02:42:11.794 [9740] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Apr 24, 2020 02:42:15.818 [2316] ERROR - Error issuing curl_easy_perform(handle): 28
Apr 24, 2020 02:42:15.919 [12864] ERROR - Error issuing curl_easy_perform(handle): 28
I’ve had it for years though on my server and I don’t think it causes any issues.
Plex Media Server Logs_2020-04-25_21-14-06.zip (638.7 KB)
Please allow me to rephrase.
I am the curator of the NAS Compatibility List.
That list shows everything Plex is supported on in the NAS world.
To be added to that list, a NAS must have a minimum CPU performance of 700 Passmarks.
Those above 400 but below 700 are flagged in Yellow with a warning.
Anything below 400 is removed or rejected.
Your CPU is 409.
The normal CPU load PMS required, regardless how it used to be, has grown.
What makes matters worse, which I hear from friends using windows all the time is how heavy Win 10 has become.
Timeouts are because the CPU can’t do the work in time.
and I’m saying the original OP may have an under powered server, however my CPU and GPU are more than enough and I still get this error on startup. and periodically throughout the logs
it doesn’t actually seem to effect anything so I don’t really care, but the explanation that it is a timeout error I don’t buy
clean DB, Clean Bundles, fresh start
Apr 26, 2020 01:23:48.577 [9696] INFO - Plex Media Server v1.19.1.2701-6327e27bf - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
Apr 26, 2020 01:23:48.577 [9696] INFO - Windows version: 10.0 (Build 18363), language en-US
Apr 26, 2020 01:23:48.577 [9696] INFO - 8 2712 MHz processor(s): Architecture=0, Level=6, Revision=24067 Processor Identifier=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
Apr 26, 2020 01:23:48.718 [9904] INFO - OCSP: Successfully retrieved response from cache.
Apr 26, 2020 01:23:50.703 [1628] WARN - [Preferences] No update channels loaded, so showing the previously-selected channel, labelled ‘unknown’ since we don’t really know the name.
Apr 26, 2020 01:23:50.896 [11368] INFO - Refreshing paths watched by LibraryUpdateManager
Apr 26, 2020 01:23:57.036 [6736] ERROR - Error issuing curl_easy_perform(handle): 28
Apr 26, 2020 01:23:57.343 [12704] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Apr 26, 2020 01:23:58.708 [5388] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (2b22fec7-af06-4581-b30c-ba905ea5dfd3, expected 1a013d5a-3128-42d5-b0c0-16a1ef64bfa9)
Apr 26, 2020 01:23:58.980 [2608] INFO - [PlexRelay] Allocated port 17343 for remote forward to 127.0.0.1:32401
Apr 26, 2020 01:23:58.988 [2608] INFO - [PlexRelay] Allocated port 22495 for remote forward to 127.0.0.1:32401
Apr 26, 2020 01:23:58.994 [2608] INFO - [PlexRelay] Allocated port 17305 for remote forward to 127.0.0.1:32401
Apr 26, 2020 01:24:04.018 [10796] ERROR - Error issuing curl_easy_perform(handle): 28
added debug logs on startup for you to see
debug_easycurl.zip (1.7 MB)
I am the one that oriinally posted.
I get it, the cpu is too old although I used to run a pms on that server until a few years ago. But very likely it was an older version of plex with lower hardware requirements.
I underestimated the fact that I bought that mini pc 8 years ago.
That said, I know that Windows is heavy. That’s why I tried to install ubuntu on that mini pc.
I can tell you it’s even slower, even after I replaced the original hd with a ssd.
I guess I just need to try another server.
Thanks again.
Federico
I literally just said thats not the issue, I have a server CPU and it gets the error on startup… so thats not the reason for the error
Hello Miniserver1, I read your post and I wasn’t just ignoring it.
I searched everywhere for this error, that apparently might seem the same error that you get…
The main error is alway 28, but often the error afterwards is different and event the solutions that people found are different.
However, in my log, after the error 28 there is another error (that I don’t see in your log)
HTTP simulating 408 after curl timeout.
I think this is the one ChuckPa was referring to.
I think we might have different issues. One thing is sure, my mini pc is extremely slow with ubuntu.
yeah the http error after yours is most likely the underlying issue, I do not have these in my logs and always just the '28" easycurl issue… Im tempted on testing on other hardware to see what happens however this is the most powerful PC I have available to me with dedicated graphics (Quadro) so I dont think Id change… maybe an OS refresh? Database refresh? these things would take days to do so I’m not sure I want to investigate further.
essentially none of my users have reported issues I just see this in the logs and nowhere have I seen a reason or solution.
even submitted the debug logs on startup for it above
I have this same error right now on a Qnap. it looks like it connects so i can access it outside my home. but after a bit i keep see that error .
MessageError issuing curl_easy_perform(handle): 28
here is my logs. Plex Media Server Logs_2020-06-04_21-25-16.zip (2.9 MB)
