Error loading Library, but Collections work
Server Version#: 1.19.3.2764
Starting yesterday, I was unable to view my Libraries. When I click on either of my Movies or TV Shows libraries, I receive “There was an unexpected error loading this library”, strangely though, when I change it to Collections, I see them, and I can play movies within those Collections. I’ve tried rescanning the library, but it just temporarily flashes placeholder icons of where my media would be, and then gives me the error again.
In unRaid logs, I see:
Critical: libusb_init failed
[s6-finish] sending all processes the KILL signal and exiting.
Any thoughts? This is very strange that Libraries won’t load, but Collections will.
SOLVED. In case anyone comes across this again.
I stopped Plex, backed up the database file, deleted it, and restarted Plex. I had to recreate my Libraries and let Plex do its full scan again, but it works now.
In unRaid, the database file is located at: “\appdata\PlexMediaServer\Library\Application Support\Plex Media Server\Plug-in Support\Databases” (if you’re using the official PMS container). And the database file is titled com.plexapp.plugins.library.db.
