Error: no such collation sequence: naturalsort
Server Version#: 1.16.5.1554
Debian Buster - Debian GNU/Linux 10 \n \l
Player Version#: 1.3.1.916-1cb2c34d
Logs provided.
Hello,
While checking my database with sqlite3 com.plexapp.plugins.library.db "PRAGMA integrity_check" , I often find that my database has the above error.
I can always fix it with the steps provided on https://support.plex.tv/articles/201100678-repair-a-corrupt-database/?_ga=2.45712420.1661355112.1568237457-988487238.1567965059, but the error comes always back.
I researched this error on this forum, but I could not find out if this is a real corruption or if it by design, and how to solve it definitely.
Can somebody confirm this error does no harm as said in some topics or should I fix this and how?
Thanks in advance for your help
Plex Media Server Logs_2019-09-14_16-47-25.zip (3.4 MB)
By design
Thank you for the quick answer!
Is it possible to elaborate a little bit? Or a link where I can find more information?
Am I correct assuming that if this is the only error the check gives me, there is no reason to repair and the check is actually “OK”?
TIA
Sadly there’s no info avail, and yes, no need to do a repair.
Most easy way to see is if repair is needed, is either to check if scheduled backup of the database fails, or by having notifications switched on, so you’ll get slammed on your mobile device, if curroption happens
