ERROR - Too many crashdumps detected / retries disallowed!
Server Version#: Version 1.29.2.6364
Plex Media Server Logs_2022-11-15_12-31-56.zip (66.0 KB)
does anyone know what is causing this? this dont sound good.
this happened within few minutes after starting plex up.
It means your server seems to have crashed or otherwise “abnormally exited” when you last run the app. Plex tries to send a crashdump with technical details about the crash to Plex. This has failed because your server has already tried sending more crashdumps over a period of time than allowed – this is intended to avoid apps which are in a permanent crash cycle to repeatedly send the same information.
You might want to look at if/why your server has beforehand crashed or exited abnormally. This particular error line from your logs should have no immediate impact on your server itself.
i kind of assumed it meant plex has abnormally shutdown. although i right click and exit before i backup and or restore plex database. pc hasn’t shutdown restarted by its self or plex ether. i do this often while testing what triggers photo timeline to go bonkers.
i just right clicked on plex and said close.
then deleted everything in plex media folder and started from scratch.
didnt add any media, just checked the logs and still shows crashdump errors
