Errors on quit/disconnect
I'm getting error messages in the Terminal when I quit PlexConnect using control-C. When I first tried out PlexConnect on my MacBook Pro (OS X )10.8.3, I never saw these errors. Are these messages normal? PlexConnect seems to be working fine for me otherwise as long as I don't install it on my OS X Server.
WebServer : ^C received.
WebServer : Shutting down.
DNSServer : ^C received.
DNSServer : Shutting down.
Traceback (most recent call last):
  File "/Users/user/PlexConnect/PlexConnect.py", line 72, in
    key = raw_input()
KeyboardInterrupt
Exception in thread QueueFeederThread (most likely raised during interpreter shutdown):
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 552, in __bootstrap_inner
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 505, in run
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/queues.py", line 259, in _feed
: 'NoneType' object is not callable
PlexConnect is currently designed to exit gracefully if you hit enter when the terminal window is focused.
Very nice. It wasn't in the FAQ so I assumed I had to kill it like any other Terminal process.
It does output info about it when it starts up but it is easy to miss.
