Exception when opening MyPlex
When I try to open MyPlex in Plexconnect an exception occurs. Was it supposed to work already?
This is what comes by in the output
21:51:25 WebServer: serving .xml: /myplex
21:51:25 XMLConverter: XML_ExpandNode - Error in cmd ADDXML, line
    {{VAR(sections:NoKey:FALSE)}}
Traceback (most recent call last):
  File "/Users/peter/PlexConnect/XMLConverter.py", line 489, in XML_ExpandNode
    res = getattr(g_CommandCollection, 'TREE_'+cmd)(elem, child, src, srcXML, param)
  File "/Users/peter/PlexConnect/XMLConverter.py", line 804, in TREE_ADDXML
    PMS = PlexAPI.getXMLFromMultiplePMS(UDID, path, type, self.options)
  File "/Users/peter/PlexConnect/PlexAPI.py", line 363, in getXMLFromMultiplePMS
    XML = getXMLFromPMS(baseURL, path, options, token)
  File "/Users/peter/PlexConnect/PlexAPI.py", line 295, in getXMLFromPMS
    response = urllib2.urlopen(request)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 127, in urlopen
    return _opener.open(url, data, timeout)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 404, in open
    response = self._open(req, data)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 422, in _open
    '_open', req)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 382, in _call_chain
    result = func(*args)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1214, in http_open
    return self.do_open(httplib.HTTPConnection, req)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1187, in do_open
    r = h.getresponse(buffering=True)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1045, in getresponse
    response.begin()
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 409, in begin
    version, status, reason = self._read_status()
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 373, in _read_status
    raise BadStatusLine(line)
BadStatusLine: ''
21:51:25 XMLConverter: XML_ExpandNode - Error in cmd COPY, line
  File "/Users/peter/PlexConnect/XMLConverter.py", line 739, in TREE_COPY
    src, srcXML, tag = self.getBase(src, srcXML, tag)
  File "/Users/peter/PlexConnect/XMLConverter.py", line 677, in getBase
    src = self.PMSroot[srcXML]
KeyError: 'MyPlexSections'
              {{VAR(sections:NoKey:TRUE)}}
  File "/Users/peter/PlexConnect/XMLConverter.py", line 753, in TREE_COPY
    for elemSRC in src.findall(tag):
AttributeError: 'NoneType' object has no attribute 'findall'
Yes... I can confirm I already used it.
Ah ok, then I am curious what is causing the exception on my system
Ah, I found something, I also tried Cloud syncing, now I have removed that and the crash does not occur anymore and I see other servers as well. Maybe that helps finding the problem
Me too. Will need more details though: Version/download date, python version, OS, ... basically everything in "How to report an issue...".
Cloud syncing is new (beta) option in PMS You can sync a movie/serie to a cloud service like dropbox or copy.com The movie will automatically be converted just like local syncing to a device. This cloud syncing will behave like a PMS server so it will also show up as a seperate PMS server in the MyPlex list.
I've looked into the code what could be the problem and I think I found it. The cloud sync pms is available at https://my.plexapp.com:443 but Plexconnect is trying to open the url at http://my.plexapp.com:443
At several places in XMLConverter.py the code
is being used and now there is http hardcoded which goes wrong for the https url of cloudsync
Room for improvement... :-D
The problem is how to determine if you need https or http
You can't know for sure by looking at the port only or is the info perhaps avaiable in the MyPlex api where the addresses of the PMS'es are being retrieved?
-> https://my.plexapp.com/pms/servers
We got it all! :-)
We got it all! :-)
Yep, I found it already. I now can open the Cloud Sync PMS as well ;) It is only not yet playing, going to dig further ;-)
We got it all! :-)
I implemented it in a fork. Hope you can merge it in the mainbranch. https for MyPlex server is now working correctly
