fhb : Thanks alot, the new scrapper fixed the problem, but it sure is a b**** to rescan 500+ movies
Anyway, I looked in the code what is that youtube thingy for? dont see that anyware on the generated .html
/mkh
As far as I know for Trailers (try clicking on a tvshow cover)
Is it possible that one of these scripts can be modified to either show watched movies vs unwatched,
Since we are going to need to rescrape for PLEX 9, it would be useful to have this info quickly
available. Thanks.
Cant find the place in Plex where i can launch the script, anyone who can help?
The script was made for Plex 8 and wonāt work with Plex 9.
any chance of getting something similar for plex 9?
if the original author of the script wants to do so
Iād be happy to modify it, but donāt want to make my own from scratch.
Here is an updated/similar topic: http://forums.plexapp.com/index.php/topic/19053-plex-web-export/
Should be helpful to many.
this is great, thanks for the info
i cannot find how to make any of these scripts run from within Plex. Any please help?
Iām sorry I havenāt been around to see if I could modify this for Plex 9, but Iām glad that someone else has made something similar for Plex 9. Iāll check it out in the other thread later.
Hi willba, Iāve made a version for Plex 9, hopefully itās similar to what youāre looking for?
http://forums.plexapp.com/index.php?/topic/19053-plex-web-export/
I do not fear having to modify the script to be compatible. As the information provided is stored in a database and query this database, we are fine. You are right, but do not spend too much time working on them since the new version is just around is not really expected that anyway.
Unzip the attached into ~/Library/Application Support/Plex/scripts/ (~/Library means the library folder in your home folder). Be sure that the folder is included - so you end up with ~/Library/Application Support/Plex/scripts/plexport/default.py
I dont know where that is⦠Home folder is that were i have the moive files or in were??
Hey sorry if this is particularly noobtacular but can I use this with Windows and if so how would I install it? Thanks for the help!
I recognize that this is still a topic. I made a PHP version. You can see the source code here
Since someone necroād this topic that was deep within the bowels of the catacombs, See also the following Channel bundles that can just be dropped into Plex Plug-ins - no external apps/scripts/servers necessary to get the data from libraries.
[REL] Plex2CSV
[REL] Plex-Export
