Server Version#: 1.23.2.4656
Player Version#: 4.59.2
In case I ever lose my server/libraries due to some glitch, is there a way to export my playlists to a .txt or .html file, so I can manually recreate them again, if I have to?
Try WebTools
And adding to @OttoKerner here:
Do try WebTools-NG as well, since more easy to use, and still been developed
But it doesn’t do playlists, yet. Or did I miss that?
I’m afraid so ![]()
Thanks, but I’m not computer savvy enough to understand how Webtools works. It’s very disappointing that Plex lacks such a basic and simple function and that you have to mess around with third party plugins!
I installed the WebTools plugin in the folder per the instructions. Where do I find it in Plex? I don’t see it.
As outlined in the doc, you need to browse towards http://<IP_OF_SERVER>:33400
And once more, and as the author of both WebTools Plugin and WebTools-NG, I do recommend the latest!
What is <IP_OF_SERVER>?
The IP Address of your Plex Media Server…
And AGAIN!!!
Try WebTools-NG !!!
So much more intuitive, no installs, and not a dead plugin!
But it was mentioned above that it doesn’t do playlists…or does it? I want to export my playlists.
And I said it did!
Otto was beta testing an early version, where it didn’t yet.
Follow the links I gave above
I entered my username and password (2FA blank). When I hit sign in, nothing happens
Please post in this thread, as well as specify what OS you are running, as well as logs if possible (Troubleshooting · WebTools-NG/WebTools-NG Wiki · GitHub)
