Exporting music playlists
How can I export a music playlist for use in a different music app?
There’s a 3rd-party app called WebTools that can do this.
Thanks. That looks complicated - no m3u option.
How about importing playlists from iTunes?
It’s actually very simple. WebTools saves a .m3u8 file. Many apps can open those as well as .m3u. In most cases, you can simply change the extension of the file to .m3u.
I found this that explains the difference:
Information About The M3U8 File Format
Plex can import your iTunes playlists when you create a library. I don’t use iTunes, so I’ve never tried it. This Help page has a bit about it:
https://support.plex.tv/articles/200288926-creating-libraries/
Thanks. I’ll give that a try.
