Hi, I’m currently using Plex on a cheap VPS that can’t handle transcoding at all. I am able to watch anything if I select a external player to watch my media (VLC or mpv), the problem is: both of them can’t recognize subtitles. I can select multiple audio tracks but the subtitles that appear on the built-in Plex player disappear on the external players. I’m referring to external subtitles (movie.mkv and at the same folder movie.srt). Is there any solution for this?
have you tried accessing your Plex sever via DLNA? that should enable all the subtitles as well…
to activate on your Plex server go to Settings > Server > DLNA.
to activate on your Plex server go toSettings > Server > DLNA.
I forgot to tell that this VPS is a remote server so I can’t use DLNA.
you didn’t forget… just an indicator for me to get offline and into bed
Anyone? I really want to solve this problem.
I found the answer:
I found the solution!
Now I can play all my media with direct play even 10gb+ 1080p MKV! (P.S.: My VPS has 512MB RAM and 1 Core)
