Extract CC from MKV !!HELP!!
I thought I saw a post where someone alluded to taking a 1.7.x MKV and extracting Closed Captions from it.
Can someone post what they did?
here’s the thread:
forums.plex.tv/discussion/275781/new-update-screws-subtitle-post-processing
@sudheeshb said:
I fully agree with OP. This is one of the key feature which many of us uses. You may the try the following work around ( not a good one ).
Extract the TS from the MKV. You can use ffmpeg for this.
  1. ffmpeg -i input.mkv -vcodec copy output.ts
  2. Now you can extract closed caption from the TS file. You may use ffmpeg or ccextractor for this.
testing.
seems to work so far.
will let you know
thanks
What is the command to extract the closed caption with ffmpeg?
Answered in your other thread, but for those that end up here is what I found on stackoverflow:
ffmpeg -f lavfi -i “movie=test.ts[out0+subcc]” -map s output.srt
Thanks.
Will test soon
Thank you. Is there a batch command to copy a whole directory of mkv to ts?
OK
I tried the above and am getting about a million of these:
Error while decoding stream #0:1: Invalid data found when processing input
[ac3 @ 0000000002634220] exponent 25 is out-of-range
[ac3 @ 0000000002634220] error decoding the audio block
[ac3 @ 0000000002634220] frame sync error
the TS file resulting, wont process under ccextractor
