Are there any plans to implement the new extras section in movies to plexconnect?
Just added extras, grab the newest commit and try it out
also added another version of it :)
https://forums.plex.tv/topic/100363-new-library-view-layout/page-32?p=704079
roidy: Awesome, works perfectly. Just made my day :)
stoffez: I really like your custom skin :) Do you have a link to your updated github with extras? :)
I see that it is still on version 0.4. Do i just do a update via Openplex ?
Regards
Gerrit
ops forgot to push :D its on my git now :)
Stoffez: Could you please post the link to your git? Been searching but can't seem to find it :)
I found the link.
Awesome addition and nice work on the skin! :)
I have one suggestion. In the default skin the extras appear if there are any extras, otherwise not. Would be nice if you could implement that if there are no extras then the watch_status button appears :)
This is now fixed.. thx for the feedback
Hmm seems to some sort of bug in the code.
The Extras button appears on some movies and on some it doesn't, even though there are extras in both :/
I have found if you select the movie from the Recently Added section on the front screen the button doesn't show up. But if I select the movie from the All Movies section it does.
These bugs have now been found and removed..
it now also work on the library grid
thx for the input :)
For some reason I can't access the Library. Seems to hang on "Accessing Trailers"+
Tashheley: have you tried the latest update?
I have not. Probably won't have time until next week.
Just added extras, grab the newest commit and try it out :)
Thank you for adding trailers and extras - it is so slick! :D
Is it possible to use extras trailers source for the trailer button?
