I’m on the same version, 1.13.5.5332, and having the same issue. I can play them on Web, but not Android or Chromecast.
Not Working:
Sep 12, 2018 04:58:47.879 [0x7f5c057fe700] DEBUG - TranscodeUniversalRequest: using augmented profile Chromecast
Sep 12, 2018 04:58:47.880 [0x7f5c057fe700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/9024?includeBandwidths=1&offset=0&X-Plex-Session-Identifier=gdlj5abv5h94579ksvv4xoty
Sep 12, 2018 04:58:47.880 [0x7f5c057fe700] DEBUG - Auth: authenticated user 1 as MaLaCoiD
Sep 12, 2018 04:58:47.886 [0x7f5c057fe700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 12, 2018 04:58:47.886 [0x7f5c057fe700] DEBUG - Selecting best audio stream for part ID 11162 (autoselect: 1 language: en)
Sep 12, 2018 04:58:47.886 [0x7f5c057fe700] DEBUG - We're going to try to auto-select a subtitle.
Sep 12, 2018 04:58:47.886 [0x7f5c057fe700] DEBUG - Audio Stream: 22171, Subtitle Stream: -1
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - Scaled up video bitrate to 4005Kbps based on 1.500000x fudge factor.
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: Selected protocol http; container: mkv
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: analyzing media item 11056
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: Direct Play is disabled
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: no direct play video profile exists for http/mkv/h264
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: no direct play video profile exists for http/mkv/h264/aac
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - September 10, 2018 - video.bitrate limitation applies: 2670 > 2000
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: no remuxable profile found, so video stream will be transcoded
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - MDE: The Rachel Maddow Show - S2018 E171 - September 10, 2018: selected media 0 / 11056
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - Streaming Resource: Calculated bandwidth of 2181kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 2000kbps
Sep 12, 2018 04:58:47.887 [0x7f5c057fe700] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - Scaled up video bitrate to 4005Kbps based on 1.500000x fudge factor.
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 41
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - Scaled maximum bitrate for resolution reduction to 1270Kbps.
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - MDE: Selected protocol http; container: mkv
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - MDE: analyzing media item 11056
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: Direct Play is disabled
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: no direct play video profile exists for http/mkv/h264
Sep 12, 2018 04:58:47.888 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: no direct play video profile exists for http/mkv/h264/aac
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - September 10, 2018 - video.bitrate limitation applies: 2670 > 2000
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - MDE: E171 - September 10, 2018: no remuxable profile found, so video stream will be transcoded
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - Scaled up video bitrate to 4005Kbps based on 1.500000x fudge factor.
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - Scaled maximum bitrate for resolution reduction to 1270Kbps.
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - MDE: The Rachel Maddow Show - S2018 E171 - September 10, 2018: selected media 0 / 11056
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - Streaming Resource: Adding session 0x7f5c2b1bd660:gdlj5abv5h94579ksvv4xoty which is using 1415kbps of WAN bandwidth. Used is now 1415kbps
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - Streaming Resource: Adding session 0x7f5c2b1bd660:gdlj5abv5h94579ksvv4xoty which is using transcoder slot. Used slots is now 1
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - Streaming Resource: Added session 0x7f5c2b1bd660:gdlj5abv5h94579ksvv4xoty
Sep 12, 2018 04:58:47.889 [0x7f5c057fe700] DEBUG - Streaming Resource: Reached Decision id=9024 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=11056 part=(id=11162 decision=transcode container=mkv protocol=http streams=(Video=(id=22169 decision=transcode bitrate=1270 encoder=libx264 width=720 height=406) Audio=(id=22171 decision=copy channels=2 rate=44100))))
Sep 12, 2018 04:58:47.891 [0x7f5c2cffe700] DEBUG - Completed: [68.107.11.19:24998] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F9024&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=wan&maxVideoBitrate=2000&directStreamAudio=1&mediaBufferSize=30720&session=ebsd21q9izegkx66thyyub5o&offset=0&subtitles=burn©ts=1 (16 live) TLS GZIP 13ms 1426 bytes (pipelined: 1)
Sep 12, 2018 04:58:48.052 [0x7f5c2d7ff700] DEBUG - Auth: authenticated user 1 as MaLaCoiD
Sep 12, 2018 04:58:48.052 [0x7f5c037fa700] DEBUG - Request: [68.107.11.19:24942 (WAN)] GET /:/timeline?ratingKey=9024&key=%2Flibrary%2Fmetadata%2F9024&playQueueItemID=8579&state=playing&hasMDE=1&time=0&duration=0 (17 live) TLS GZIP Signed-in Token (MaLaCoiD)
Sep 12, 2018 04:58:48.053 [0x7f5c037fa700] DEBUG - Client [gdlj5abv5h94579ksvv4xoty] reporting timeline state playing, progress of 0/0ms for guid=, ratingKey=9024 url=, key=/library/metadata/9024, containerKey=, metadataId=9024
Sep 12, 2018 04:58:48.058 [0x7f5c037fa700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 12, 2018 04:58:48.058 [0x7f5c037fa700] DEBUG - Selecting best audio stream for part ID 11162 (autoselect: 1 language: en)
Sep 12, 2018 04:58:48.058 [0x7f5c037fa700] DEBUG - We're going to try to auto-select a subtitle.
Sep 12, 2018 04:58:48.058 [0x7f5c037fa700] DEBUG - Audio Stream: 22171, Subtitle Stream: -1
Sep 12, 2018 04:58:48.059 [0x7f5c037fa700] DEBUG - [Now] User is MaLaCoiD (ID: 1)
Sep 12, 2018 04:58:48.059 [0x7f5c037fa700] DEBUG - [Now] Device is Chromecast (Chromecast).
Sep 12, 2018 04:58:48.060 [0x7f5c037fa700] DEBUG - [Now] Profile is Chromecast
Sep 12, 2018 04:58:48.060 [0x7f5c037fa700] DEBUG - [Now] Updated play state for /library/metadata/9024.
Sep 12, 2018 04:58:48.064 [0x7f5c037fa700] DEBUG - Statistics: (twx9iunqfcqamdlm06b4au4j) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
Sep 12, 2018 04:58:48.119 [0x7f5c2cffe700] DEBUG - Completed: [68.107.11.19:24942] 200 GET /:/timeline?ratingKey=9024&key=%2Flibrary%2Fmetadata%2F9024&playQueueItemID=8579&state=playing&hasMDE=1&time=0&duration=0 (16 live) TLS GZIP 67ms 540 bytes (pipelined: 4)
Sep 12, 2018 04:58:48.213 [0x7f5c2d7ff700] DEBUG - Auth: authenticated user 1 as MaLaCoiD
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] DEBUG - Request: [68.107.11.19:24998 (WAN)] POST /log (16 live) TLS GZIP Signed-in Token (MaLaCoiD)
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] X-Plex-Chunked: 1
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] copyts: 1
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] X-Plex-Client-Profile-Extra: add-limitation(scope=videoCodec&scopeName=*&type=upperBound&name=video.frameRate&value=60&replace=true)+add-limitation(scope=videoCodec&scopeName=*&type=upperBound&name=video.bitrate&value=2000&replace=true)+add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=42&replace=true)+add-limitation(scope=videoAudioCodec&scopeName=aac&type=upperBound&name=audio.channel&value=2)
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] subtitles: burn
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] offset: 0
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] session: ebsd21q9izegkx66thyyub5o
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] X-Plex-Session-Identifier: gdlj5abv5h94579ksvv4xoty
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] mediaBufferSize: 30720
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] directStreamAudio: 1
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] maxVideoBitrate: 2000
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] location: wan
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] audioBoost: 100
Sep 12, 2018 04:58:48.218 [0x7f5c197ff700] INFO - [Chromecast] subtitleSize: 100
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] directStream: 1
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] directPlay: 0
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] fastSeek: 1
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] protocol: http
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] partIndex: 0
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] mediaIndex: 0
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] path: /library/metadata/9024
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] hasMDE: 1
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] [Transcoder] Video (decision) options
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] X-Plex-Chunked: 1
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] copyts: 1
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] X-Plex-Client-Profile-Extra: add-limitation(scope=videoCodec&scopeName=*&type=upperBound&name=video.frameRate&value=60&replace=true)+add-limitation(scope=videoCodec&scopeName=*&type=upperBound&name=video.bitrate&value=2000&replace=true)+add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=42&replace=true)+add-limitation(scope=videoAudioCodec&scopeName=aac&type=upperBound&name=audio.channel&value=2)
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] subtitles: burn
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] offset: 0
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] session: ebsd21q9izegkx66thyyub5o
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] X-Plex-Session-Identifier: gdlj5abv5h94579ksvv4xoty
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] mediaBufferSize: 30720
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] directStreamAudio: 1
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] maxVideoBitrate: 2000
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] location: wan
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] audioBoost: 100
Sep 12, 2018 04:58:48.219 [0x7f5c197ff700] INFO - [Chromecast] subtitleSize: 100
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] protocol: http
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] partIndex: 0
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] mediaIndex: 0
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] path: /library/metadata/9024
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] hasMDE: 1
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] [Transcoder] Video (start) options
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] Direct Play: false
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] Protocol: http
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] Player: html
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] [PDE] Player decision
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] videoResolution: 720
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] bitrate: 2000
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] canDirectStreamAudio: true
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] canDirectStreamVideo: false
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] canDirectPlay: false
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] canPlay: true
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] [MDE] Finished analysis of 720 (mkv, h264, aac, 31, main)
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] WARN - [Chromecast] [MDE] Invalid profile property; bitrate: 2670 > 2000
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] WARN - [Chromecast] [MDE] Unable to validate bitDepth; re-analyze the media if possible
Sep 12, 2018 04:58:48.220 [0x7f5c197ff700] INFO - [Chromecast] [MDE] Starting analysis of 720 (mkv, h264, aac, 31, main)
Sep 12, 2018 04:58:48.221 [0x7f5c2cffe700] DEBUG - Completed: [68.107.11.19:24998] 200 POST /log (16 live) TLS GZIP 3ms 268 bytes (pipelined: 2)
Sep 12, 2018 04:58:48.457 [0x7f5c2d7ff700] DEBUG - Auth: authenticated user 1 as MaLaCoiD
Sep 12, 2018 04:58:48.457 [0x7f5c057fe700] DEBUG - Request: [68.107.11.19:25782 (WAN)] GET /video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F9024&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=wan&maxVideoBitrate=2000&directStreamAudio=1&mediaBufferSize=30720&session=ebsd21q9izegkx66thyyub5o&offset=0&subtitles=burn©ts=1 (17 live) TLS Signed-in Token (MaLaCoiD)
Sep 12, 2018 04:58:48.458 [0x7f5c057fe700] DEBUG - Found session GUID of ebsd21q9izegkx66thyyub5o in session start.
Sep 12, 2018 04:58:48.458 [0x7f5c057fe700] DEBUG - TranscodeUniversalRequest: using augmented profile Chromecast
Sep 12, 2018 04:58:48.459 [0x7f5c057fe700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/9024?checkFiles=1&includeBandwidths=1&offset=0&X-Plex-Session-Identifier=gdlj5abv5h94579ksvv4xoty
Sep 12, 2018 04:58:48.460 [0x7f5c057fe700] DEBUG - Auth: authenticated user 1 as MaLaCoiD
Sep 12, 2018 04:58:48.468 [0x7f5c057fe700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 12, 2018 04:58:48.469 [0x7f5c057fe700] DEBUG - Selecting best audio stream for part ID 11162 (autoselect: 1 language: en)
Sep 12, 2018 04:58:48.469 [0x7f5c057fe700] DEBUG - We're going to try to auto-select a subtitle.
Sep 12, 2018 04:58:48.469 [0x7f5c057fe700] DEBUG - Audio Stream: 22171, Subtitle Stream: -1
Sep 12, 2018 04:58:48.470 [0x7f5c057fe700] DEBUG - Cleaning directory for session ebsd21q9izegkx66thyyub5o ()
Sep 12, 2018 04:58:48.470 [0x7f5c057fe700] DEBUG - Starting a transcode session ebsd21q9izegkx66thyyub5o at offset -1.0 (state=3)
Sep 12, 2018 04:58:48.471 [0x7f5c057fe700] INFO - CodecManager: obtaining decoder 'h264'
Sep 12, 2018 04:58:48.471 [0x7f5c057fe700] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/h264_decoder?build=linux-ubuntu-x86_64&deviceId=7fa6f785-c9fb-49e0-9ce8-b35b2a8b561c&oldestPreviousVersion=1%2E0%2E0%2E2261-a17e99e&version=e944d3a-1322
Sep 12, 2018 04:58:48.526 [0x7f5c2d7ff700] DEBUG - Auth: authenticated user 1 as MaLaCoiD
Sep 12, 2018 04:58:48.526 [0x7f5c197ff700] DEBUG - Request: [68.107.11.19:24942 (WAN)] GET /playQueues/1139?repeat=0&own=1&includeChapters=1&includeGeolocation=1 (17 live) TLS GZIP Signed-in Token (MaLaCoiD)
Sep 12, 2018 04:58:48.527 [0x7f5c197ff700] DEBUG - PlayQueue: total generated: 1, before cursor: 0, after cursor: 0
Sep 12, 2018 04:58:48.528 [0x7f5c197ff700] DEBUG - PlayQueue: No need to refresh, active window is operational.
Sep 12, 2018 04:58:48.533 [0x7f5c197ff700] DEBUG - PlayQueue: Client twx9iunqfcqamdlm06b4au4j requested ownership of play queue 1139, but already had it.
Sep 12, 2018 04:58:48.535 [0x7f5c197ff700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 12, 2018 04:58:48.535 [0x7f5c197ff700] DEBUG - Selecting best audio stream for part ID 11162 (autoselect: 1 language: en)
Sep 12, 2018 04:58:48.535 [0x7f5c197ff700] DEBUG - We're going to try to auto-select a subtitle.
Sep 12, 2018 04:58:48.535 [0x7f5c197ff700] DEBUG - Audio Stream: 22171, Subtitle Stream: -1
Sep 12, 2018 04:58:48.537 [0x7f5c2d7ff700] DEBUG - Completed: [68.107.11.19:24942] 200 GET /playQueues/1139?repeat=0&own=1&includeChapters=1&includeGeolocation=1 (17 live) TLS GZIP 11ms 1471 bytes (pipelined: 5)
Sep 12, 2018 04:58:48.600 [0x7f5c057fe700] DEBUG - HTTP 200 response from GET https://plex.tv/api/codecs/h264_decoder?build=linux-ubuntu-x86_64&deviceId=7fa6f785-c9fb-49e0-9ce8-b35b2a8b561c&oldestPreviousVersion=1%2E0%2E0%2E2261-a17e99e&version=e944d3a-1322
Sep 12, 2018 04:58:48.601 [0x7f5c057fe700] ERROR - Failed to open tmp file: /config/Library/Application Support/Plex Media Server/Codecs/e944d3a-1322-linux-ubuntu-x86_64/libh264_decoder.so.tmp-e944-daee-6e8f-96bc - Permission denied
Sep 12, 2018 04:58:48.601 [0x7f5c057fe700] ERROR - Error configuring transcoder: Decoder install failed: h264
Sep 12, 2018 04:58:48.601 [0x7f5c057fe700] DEBUG - Streaming Resource: Terminating session 0x7f5c2b1bd660:gdlj5abv5h94579ksvv4xoty which is using 1415kbps of WAN bandwidth. Used is now 0kbps
Sep 12, 2018 04:58:48.601 [0x7f5c057fe700] DEBUG - Streaming Resource: Terminating session 0x7f5c2b1bd660:gdlj5abv5h94579ksvv4xoty which is using transcoder slot. Used slots is now 0
Sep 12, 2018 04:58:48.601 [0x7f5c057fe700] DEBUG - Streaming Resource: Terminated session 0x7f5c2b1bd660:gdlj5abv5h94579ksvv4xoty with reason Conversion failed. A required codec could not be found or failed to install.
Sep 12, 2018 04:58:48.601 [0x7f5c103ff700] DEBUG - Killing job.
Sep 12, 2018 04:58:48.601 [0x7f5c103ff700] DEBUG - Job was already killed, not killing again.
Sep 12, 2018 04:58:48.601 [0x7f5c103ff700] DEBUG - Stopping transcode session ebsd21q9izegkx66thyyub5o
Sep 12, 2018 04:58:48.601 [0x7f5c117fe700] DEBUG - Cleaning directory for session ebsd21q9izegkx66thyyub5o (/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-ebsd21q9izegkx66thyyub5o-6f3bae2d-1f62-4726-86e9-a0aa16b05e73)
Sep 12, 2018 04:58:48.602 [0x7f5c2d7ff700] DEBUG - Completed: [68.107.11.19:25782] 404 GET /video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F9024&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=wan&maxVideoBitrate=2000&directStreamAudio=1&mediaBufferSize=30720&session=ebsd21q9izegkx66thyyub5o&offset=0&subtitles=burn©ts=1 (17 live) TLS 144ms 288 bytes (pipelined: 4) (range: bytes=0-)
Sep 12, 2018 04:58:48.602 [0x7f5c103ff700] DEBUG - Transcoder: Cleaning old transcode directories.
Sep 12, 2018 04:58:48.603 [0x7f5c103ff700] DEBUG - Whacked session ebsd21q9izegkx66thyyub5o, 0 remaining.
