Server Version#: 1.15.0.659
Player Version#: Using Web
Windows 10 Pro
Transcoding is not working… it actually hasn’t been for well over a year. I’ve just now started to look into it. I’ve come across a lot of threads with this issue, but haven’t been able to find a solution that works for me. I’ve repaired the media server, I’ve uninstalled and reinstalled, I’ve uninstalled / deleted registry keys / deleted local data. At this point I’m at a loss. I cannot seem to connect to plex to download the codecs, my codec folder under appdata is empty. I waited several hours even after doing all of the above and still cannot download the codecs. I cannot ping plex.tv, all packets are dropped. I have nothing in my hosts file, nor on my router that should stop the traffic. I even disconnected my phone from wifi and was unable to ping plex.tv from the terminal on my android phone. WTF. When I first setup Plex it worked perfectly, no issues, now it’s nothing but a headhache…
Please help.
Server logs: https://drive.google.com/open?id=1U4RulBWRL7RYiv2wjvbmSObaca5tiuLf
Feb 15, 2019 22:53:57.820 [5368] DEBUG - MDE: Star Wars (1977): Direct Play is disabled
Feb 15, 2019 22:53:57.820 [5368] DEBUG - MDE: Star Wars (1977): media must be transcoded in order to use the dash protocol
Feb 15, 2019 22:53:57.820 [5368] DEBUG - MDE: Star Wars (1977): no direct play video profile exists for http/mkv/h264
Feb 15, 2019 22:53:57.820 [5368] DEBUG - MDE: Star Wars (1977): no direct play video profile exists for http/mkv/h264/dca
Feb 15, 2019 22:53:57.821 [5368] DEBUG - Star Wars - audio.channels limitation applies: 7 > 6
Feb 15, 2019 22:53:57.821 [5368] DEBUG - Codecs: testing aac_mf (encoder)
Feb 15, 2019 22:53:57.822 [5368] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Feb 15, 2019 22:53:57.827 [6148] DEBUG - Completed: [127.0.0.1:49943] 200 GET /photo/:/transcode?width=1920&height=937&opacity=30&background=36383b&minSize=1&url=%2Flibrary%2Fmetadata%2F158%2Fart%2F1550292829%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (9 live) GZIP 412ms 73255 bytes (pipelined: 16)
Feb 15, 2019 22:53:57.924 [5368] DEBUG - Star Wars - audio.channels limitation applies: 7 > 6
Feb 15, 2019 22:53:57.924 [5368] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Feb 15, 2019 22:53:57.925 [5368] DEBUG - MDE: Star Wars (1977): selected media 0 / 158
Feb 15, 2019 22:53:57.925 [5368] DEBUG - Streaming Resource: Added session 0x7a28c58:qchj07fqo2pl9hcz7l3wgqh4
Feb 15, 2019 22:53:57.926 [5368] DEBUG - Streaming Resource: Reached Decision id=158 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=158 part=(id=158 decision=transcode container=mp4 protocol=dash streams=(Video=(id=1100 decision=copy width=1920 height=824) Audio=(id=1101 decision=transcode bitrate=256 encoder=aac_mf channels=2 rate=48000))))
Feb 15, 2019 22:53:57.930 [6148] DEBUG - Completed: [127.0.0.1:49995] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F158&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=5wixqcywe6g0b508lp3iiw5n&subtitles=burn&Accept-Language=en (9 live) GZIP 271ms 6891 bytes (pipelined: 6)
Feb 15, 2019 22:53:58.010 [6148] DEBUG - Auth: authenticated user 1 as patmann03
Feb 15, 2019 22:53:58.013 [12600] DEBUG - Request: [127.0.0.1:49995 (Loopback)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F158&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=5wixqcywe6g0b508lp3iiw5n&subtitles=burn&Accept-Language=en (9 live) GZIP Signed-in Token (patmann03)
Feb 15, 2019 22:53:58.013 [12600] DEBUG - Found session GUID of 5wixqcywe6g0b508lp3iiw5n in session start.
Feb 15, 2019 22:53:58.015 [12600] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Feb 15, 2019 22:53:58.016 [12600] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/158?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=qchj07fqo2pl9hcz7l3wgqh4
Feb 15, 2019 22:53:58.017 [12600] DEBUG - Auth: authenticated user 1 as patmann03
Feb 15, 2019 22:53:58.029 [12600] DEBUG - It took 0.000000 ms to retrieve 206 items.
Feb 15, 2019 22:53:58.054 [12600] DEBUG - We're going to try to auto-select an audio stream for account 1.
Feb 15, 2019 22:53:58.054 [12600] DEBUG - Selecting best audio stream for part ID 158 (autoselect: 0 language: en)
Feb 15, 2019 22:53:58.054 [12600] DEBUG - Audio Stream: 1101, Subtitle Stream: -1
Feb 15, 2019 22:53:58.066 [12600] DEBUG - Found session GUID of 5wixqcywe6g0b508lp3iiw5n in session start.
Feb 15, 2019 22:53:58.067 [12600] DEBUG - Cleaning directory for session 5wixqcywe6g0b508lp3iiw5n ()
Feb 15, 2019 22:53:58.068 [12600] DEBUG - Starting a transcode session 5wixqcywe6g0b508lp3iiw5n at offset -1.0 (state=3)
Feb 15, 2019 22:53:58.071 [12600] INFO - CodecManager: obtaining decoder 'h264'
Feb 15, 2019 22:53:58.072 [12600] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/h264_decoder?build=windows-x86-standard&deviceId=f73b7e54-d0be-4a5d-9738-f2817ac504e1&oldestPreviousVersion=1%2E15%2E0%2E659-9311f93fd&version=a22632d-2034
Feb 15, 2019 22:53:58.605 [12600] DEBUG - HTTP 429 response from GET https://plex.tv/api/codecs/h264_decoder?build=windows-x86-standard&deviceId=f73b7e54-d0be-4a5d-9738-f2817ac504e1&oldestPreviousVersion=1%2E15%2E0%2E659-9311f93fd&version=a22632d-2034
Feb 15, 2019 22:53:58.605 [12600] ERROR - Codecs: Failed to download XML for codec 'h264_decoder'
Feb 15, 2019 22:53:58.606 [12600] ERROR - Error configuring transcoder: Decoder install failed: h264
Feb 15, 2019 22:53:58.606 [12600] DEBUG - Streaming Resource: Terminated session 0x7a28c58:qchj07fqo2pl9hcz7l3wgqh4 with reason Conversion failed. A required codec could not be found or failed to install.
Feb 15, 2019 22:53:58.606 [9568] DEBUG - Killing job.
Feb 15, 2019 22:53:58.606 [9568] DEBUG - Job was already killed, not killing again.
Feb 15, 2019 22:53:58.606 [9568] DEBUG - Stopping transcode session 5wixqcywe6g0b508lp3iiw5n
