Hi, it has been 4 or 5 days now that plex doesn’t update the live tv. If I choose a channel anyway it is working ok.
I entered on live tv setup and forced a refresh, this is what I got on the log:
Aug 17, 2018 20:48:12.459 [0x7fb417ffe700] DEBUG - Activity: updated activity f98c1517-fd71-450c-a766-11a3a6b378a3 - completed 1% - Refreshing guide data
Aug 17, 2018 20:48:12.473 [0x7fb417ffe700] DEBUG - JSON parse error: Missing a closing quotation mark in string. (3645291)
Aug 17, 2018 20:48:12.492 [0x7fb417ffe700] ERROR - EPG: JSON parse error. Wrote JSON data to “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Diagnostics/EPG-onconnect-02ad76c7-71eb-4bbe-a3d8-35c4a21852db.json”
Attached is the EPG-onconnect-02ad76c7-71eb-4bbe-a3d8-35c4a21852db.json file.
Your host’s IP must have an RFC1918 address.
This is anything on your LAN of the form which matches what the modem should be giving you in the address blocks (192.168.x.x, 10.x.x.x, or 172.16.x.x -> 172.31.x.x)
Changing the IP address of “locahost” will cause chaos every time.
The address should ALWAYS be 127.0.0.1 and never changed unless you have experience in creating an alias IP …
It has been a couple of weeks since I don’t reboot it, I’ll try it later. But from the error on the logs, it’s very clear that it’s failing to update the guide because a parse error on the JSON file.
I don’t know from where plex gets it, but couldn’t the problem be with who is generating this JSON? I don’t know how many Brazilian plex users are, but I think it’s not much (using Live TV).
About the regression, I’l try to back to a previous version and then reboot the server, but it has been almost a month since I last updated PMS and this JSON Parse problem started in less than a week ago.
The question I must determine is: Did the source json change or did PMS change.
I will ask the developer for feedback.
However, from your logs, Error 28 is a Timeout error. This implies directly that the remote did not respond completely and more data is expected.
I’ve reached out directly to the dev. His private chat is marked as Holiday. I do not know if this means he will return this coming monday or later. please be aware it may take time to get the answer
