Failed to create socket on UDP port 53: [Errno 48] Address already in use
Issue description: When I run PlexConnect.py, it appears "Failed to create socket on UDP port 53: [Errno 48] Address already in use". I have googled some related topics, it seems means there have a DNS Server already run in the device, but I should have nothing in this Mac. Is this caused by dnsmasq run on Openwrt router? I have setup dnsmasq for apple tv on Openwrt. Please help. Thanks.
DNS: 192.168.1.1;
PMS: Mac Mini, OS X Mavericks(10.9), IP:192.168.1.102
Plex Media Server Version: PlexMediaServer-0.9.8.10.215-020456b-OSX
Local IP address PMS 192.168.1.102
Settings.cfg:
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 192.168.1.1
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = secure.marketwatch.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
Admin-Mac-mini:~ Admin$ cd /Users/Admin/Documents/PlexConnect-wsj
Admin-Mac-mini:PlexConnect-wsj Admin$ sudo python PlexConnect.py
Password:
20:40:16 PlexConnect: ***
20:40:16 PlexConnect: PlexConnect
20:40:16 PlexConnect: Press CTRL-C to shut down.
20:40:16 PlexConnect: started: 20:40:16
20:40:16 PlexConnect: IP_self: 192.168.1.102
20:40:16 DNSServer: started: 20:40:16
20:40:16 DNSServer: Failed to create socket on UDP port 53: [Errno 48] Address already in use
20:40:16 PlexConnect: DNSServer not alive. Shutting down.
20:40:16 PlexConnect: Shutting down.
20:40:16 PlexConnect: shutdown
Admin-Mac-mini:PlexConnect-wsj Admin$ sudo lsof -i -P | grep -i 53
UserEvent   11           root    4u  IPv4 0x2ed4d35723284a53      0t0    UDP *:*
mDNSRespo   36 _mdnsresponder    8u  IPv4 0x2ed4d357232840cb      0t0    UDP *:5353
mDNSRespo   36 _mdnsresponder    9u  IPv6 0x2ed4d35723283ee3      0t0    UDP *:5353
mDNSRespo   36 _mdnsresponder   32u  IPv4 0x2ed4d35724a589eb      0t0    UDP *:53355
mDNSRespo   36 _mdnsresponder   33u  IPv6 0x2ed4d35725fdc61b      0t0    UDP *:53355
mDNSRespo   36 _mdnsresponder   39u  IPv4 0x2ed4d3572604a92b      0t0    UDP *:53032
mDNSRespo   36 _mdnsresponder   40u  IPv6 0x2ed4d3573663adbb      0t0    UDP *:53032
mDNSRespo   36 _mdnsresponder   72u  IPv4 0x2ed4d35724a5aa53      0t0    UDP *:53
mDNSRespo   36 _mdnsresponder   73u  IPv6 0x2ed4d357232829eb      0t0    UDP *:53
mDNSRespo   36 _mdnsresponder   74u  IPv4 0x2ed4d3572bd15deb      0t0    TCP *:53 (LISTEN)
mDNSRespo   36 _mdnsresponder   77u  IPv6 0x2ed4d357362039a3      0t0    TCP *:53 (LISTEN)
ntpd       118           root   31u  IPv6 0x2ed4d3573625a9eb      0t0    UDP [2001::53aa:64c:0:2e8b:4b61:7e11]:123
miredo     164         nobody    9u  IPv4 0x2ed4d3572604a373      0t0    UDP *:53620
Plex\x20D 1732        Admin   53u  IPv4 0x2ed4d35734cc0deb      0t0    TCP 192.168.1.102:60284->ec2-54-205-33-168.compute-1.amazonaws.com:80 (ESTABLISHED)
QQ        1983        Admin   22u  IPv4 0x2ed4d35725fdea53      0t0    UDP *:50404
QQ        1983        Admin   53u  IPv4 0x2ed4d35725fdc433      0t0    UDP *:57571
QQ        1983        Admin   57u  IPv4 0x2ed4d357244cfa53      0t0    UDP *:55907
QQ        1983        Admin   59u  IPv4 0x2ed4d3573636eee3      0t0    UDP *:53466
natpmpd   6738           root    4u  IPv4 0x2ed4d35725fdcdbb      0t0    UDP 192.168.2.1:5351
mDNSRespo(nder)? What does it do on your Mac?
I have it here as well, but not listening on port 53...
Are you sure you don't have a DNSServer set up?
Thanks for quick response. I am have no idea for technical issue and for this mDNSRespo(nder), just have a search it seem a component of Mac software Bonjour? I don't know this...I found mDNSResponder in Activity Monitor, but its port apprears 96, not 53...And search Bonjour in Spotlight, appears System Preference: Sharing in the first line. Is it caused by File Sharing opening
How to fix it?Can I and How to change the port? Or disable it and just use the router dnsmasq for Plex?
Anyone can help this? Thanks.
If you have your own DSN Service setup on your router, just shut down (disable) the one shipped with PlexConnect.
In Settings.cfg there should be an option like "enable_DNSServer"... set it to False and it won't complain about port 53 already in use. You won't get the PlexConnect DNSServer part either, so make sure your own DNS is setup correctly to forward the needed addresses.
