I am constantly recieving the Failed to send invite message, despite hitting 49 out of the 100 quota. I’m not sure what is going on i have tried several things. They are registered accounts, and has been persistant now for quite some time.
Server Version#: 1.24.5.5173
Player Version#: Version 4.63.0
If you are adding them all at once, you will run into the rate limiting.
I am running into the exact same thing. I am under the 100 friend count also. (not sure why there is a limit in the first place)
@OttoKerner - Is there any chance you know where can we find out what these rate limits are? is it in the logs anywhere? are there terms we can grep for to look for this / be alerted of why things are failing?
its fair enough if things are failing for a legit reason - it would then just be nice to know what the reason is / know what the limits are - so we can work within the confines of the system.
Much appreciated
