Fanart is not showing up on Preplay screen
I just updated from PHT to OpenPHT and everything is looking great except one thing: the fanart (background) is not displayed in any of my movies or TV shows once they are selected (Preplay screen):
Yes, the fanart is visible in PlexWeb, so I know it’s there:
It is also visible in the main screen:
I looked for a preference option about fanart, but didn’t find anything that was set not to show fanart in the Preplay screen.
I am running OpenPHT 1.6.2.123-e23a7eef with the OpenPHT skin on Ubuntu 14.04 LTS. I’d appreciate any help – thank you!
Oh and as you can see, the Director and Cast also is not visible.
Please enable debug logging in preferences -> system -> advanced and share your log file from ~/.plexht/temp/
Also suggest you try with a clean ~/.plexht
Thank you, Kwiboo! Clearing this out resolved my issue.
