First off, I love Plex. I’ve been using it for a couple of years throughout the house and am amazed and thankful for all it can do.
In searching the forums it appears this has been asked for back in 2018, I’d like to raise the request again. From the FireTV client app I can create a video playlist and add a file to it, but if I want to add the same file again the app says OK but does not add it a second time. Seems like it would be a reasonable request for it to work like Spotify and other systems playlists, to ask the user “This is already in your playlist, do you want to add it again?” and then allow it.
It looks this suggestion didn’t really gain much attention.
Your best shot though will be to post this in the Feature Suggestions category. Given there’s already an existing feature suggestion you should vote/comment in that thread instead.
