[Implemented] Allow Agent settings to be set on a per-library basis
When you change a setting in one library, it affects all libraries of the same type. However, there are times when I want some of those settings to be enabled in one library, but disabled in another.
Please allow these settings to be set at the Library level, so unique settings can be saved in each library.
This got implemented at some point.
