[Feature Request] Dead simple nfo integration
I really like Plex, specially the new Plex App for Apple TV 4! I also like the Freebase agent, with all the extras, ratings and reviews. The only thing that is bothering me, is that i can not use the (movie-)titles from my nfo-files. I am happy with the scrapped summarys and so on, but i have to change the titles to often. So the only simple feature i request, is a little option in the Freebase (and maybe also in the Movie Database) agent, that says something like “Use title from nfo-file, if available”. That would be awesome! Maybe there a some other ways to achieve this, but you get my idea.
https://forums.plex.tv/discussion/38402/metadata-agents-for-exported-xbmc-library
Thank you, i already knew that plugin, but what i was looking for “Use title from nfo-file” only . The plugin will deliver all metadata from the nfo file, and, more important, you don’t get the extras and ll that.
Anyway, now i use your method from https://forums.plex.tv/discussion/135388/anleitung-deutsche-filmtitel-und-bessere-beschreibung-2/p4 with the slightly modifications from x-Timmey-x. Now i get most of the titles correctly and only have to rename a few.
