[Feature Request] Edit smart playlist filters
Currently in PMS, if I filter a media library and create a smart playlist from the filter set, there’s no way to edit my filters. I should be allowed to tweak my settings without having to:
  1. delete the “incorrect” smart playlist
  2. try to remember what filters I had set last time
  3. set same filters again, with my adjustments
  4. re-save filters as a new version of the same smart playlist
Please use the search function before posting a feature request to avoid duplicates. This helps to limit distributing votes on the same feature across a number of posts (reducing their impact/visibility).
Check out this older request with more votes and add yours :slight_smile:
=> closing this request
