Server Version#: 1.20.2.3402
Player Version#: 1.20.2.3402
The most recent post on this topic seems to be a few months old.
So it looks like there is some support for editing the filters now? I still cannot make any apparent changes; my situation is essentially identical to this: https://forums.plex.tv/t/implemented-ability-to-view-and-edit-conditions-tags-in-smart-playlists/138513/36
Anyway, is there maybe an update on this bug/feat. req.? Also, I am wondering if my filter changes are being saved but I cannot see them? Or if they are not taking at all?
When you click the action menu on a smart playlist, do you not see this? It should take you to the library with the custom filter UI open and the filters you created loaded and editable.
Sure, that has been there for a while; it just doesn’t work. Whether I save it directly, or try to sav as under anew playlist name, when you go back and look at the filters again, they appear the same as they did before I tried to edit them the first time.
Hmm, it’s working here. Couple of things I notice, though:
If I set my filters and go straight to the ‘Save’ button without first clicking ‘Apply,’ it doesn’t save the changes. Are you clicking ‘Apply’ first? It seems counter-intuitive that you have to do this, but might be the problem?
Second thing, there was a new release of the server a couple days ago. It seems unlikely, but if the above isn’t the solution, you might try the new build.
