Feature request: Could you implement the option of having the screen fade to black when pausing a movie. It would help minimizing the risk of burn in on OLED screens.
/Pauli
/Pauli
Burn-in is possible with OLED , but not likely with normal use. Most " burn-in " is actually image retention, which goes away after a few minutes. You’ll almost certainly see image retention long before it becomes permanent burn-in . Generally speaking, burn-in is something to be aware of, but not worry about.
Generally speaking - if you’re pausing long enough to fear Burn-In - hit stop instead.
I kick pausers after 1 minute in my Plexiverse.
If they want to pause for a week - they can pause Netflix <—or try - that probably won’t work for Netflix very long either.
2021 clean-up: duplicate
