I would like the ability to hide watched seasons when looking at a show. I would prefer this be a global setting that can be manually overwritten on a show-by-show basis.
For example, Chopped has 35 seasons. When I open up the show, I have to scroll over to find the first season that has an unwatched episode in order to start watching. If we were always on the latest episode, I could just order them that way to solve, but that is not always the case.
You can filter in Plex clients.
I usually set my tv show library to filter ‘unwatched’ and sorted by ‘Date viewed’.
This will sort the show which you watched last directly to the beginning of the list.
When you press play directly from there, it plays the next unwatched episode of that show.
That sorting won’t really work for me. I just got my wife used to our alpha sort, so changing it up on her is not really an option. I understand that there are workarounds to get it to work close to what I want, but not quite what I want. I figured that adding a boolean setting somewhere and toggling the visibility of seasons based on this setting && unwatched episodes == 0 seemed trivial enough.
