Feature Request: Improve configuration of "Maximum unwatched" and "Delete watched" // mod: keep
Hello,
I have shows in my Plex library that I don’t want to keep forever, but I would like them to hang around for a month or two in case I get the chance to watch them, and after I do watch them, I’d like to give my other users more than 7 days to watch them too.
Please provide more granular options for these two settings:
Make these completely user configurable. Let us specify episode count or age in days from a dropdown, and then provide an input field of a number for “Keep unwatched.” Do the same thing for “Delete watched.”
As a secondary request, please update the language in the UI to disambiguate the effective difference and/or intent between differentiating these two settings. For example: Will the “Keep unwatched” setting also delete watched episodes or not? Is “Keep only episodes I’ve watched” a common use case?
Thanks.
For ease of making this post easier to find with a search, the exact text of these features in the Plex UI is:
  • Set the maximum number of unwatched episodes to keep for the show.
  • Delete episodes after watching
  • Choose how quickly episodes are removed after the server admin has watched them.
Since this seems to be the thread to use, I guess I’ll bump it and say that I still want this. The suggestions provided are good.
Just to bump this suggestion, and also add to it - “Keep Latest Season” to keep all the episodes from the last season of a show, and remove previous seasons
Hi, i thought it would be good to have one more time setting for “Delete episode after playing”, 2 weeks.
Since most tv shows are weekly, to bridge the gap of the episode/show disappearing completely (although for a short time).
I hope you guys like the idea.
I think this will be an easy addition…
Instead of just the options for “Delete Episodes After Playing” to only include:
  • Never
  • After a day
  • After a week
  • On next refresh
Allow users to specify a number of days > 0. This could actually replace the two middle options (After a day, After a week) since you could specify with the variable “1” or “7” in their place. The “Never” and “On next refresh” options are great and should stay as is.
In many cases I’d like to keep watched items around for longer than a week, but maybe less than 30-60 days, but I can’t “automatically” have them deleted in that time frame.
Thank you for all the great work!
Omzig10
Id also like more auto-delete options.
Maybe delete old/watched episodes when the disc is starting to run out of space
I’ve never seen this option. Where is it?
@CostaHT, it’s set PER TV Show, you can find the settings in the Advanced options when editing a TV show.
@RockStar, I appreciate the comment, but click on Vote too! :slight_smile:
All out of votes, or I would have
I would like to have more option on how many episodes to keep of recored TV.
an option such as keep XX and you select how many to keep rather than just the current selections
I’m not sure I understand what you’re asking for… do you want to manually set a custom number of episodes to keep (instead of selecting one of the available options)?
That’s how it reads to me. And I would also have liked this as a feature. Because the current system is so limited that it’s only useful if you have very limited storage space.
Yes sorry for the delay in answering ! I didnt see it…
I would like to set it to keep maybe 20 episodes would be nice.
https://forums.plex.tv/t/change-the-number-of-episodes-to-keep/858350/2
Tom Sorry for the delay in ansering you but I didnt see your response…
But yes is there a way to set the number of episodes to keep to 20 ?
Rather than the options they give you…
Still waiting and hoping for this feature to be added to select how many episodes to keep rather than the limmited section we have now.
I would like to add on to this and request to also have the option to delete partially watched episodes. For example, I record the evening news daily, sometimes I may only watch half of it, but when the new one comes out, I still want to keep only the latest episode. It seems the partials just hang around until manually deleted.
Thanks!
