Feature Request - making mobile sync friendlier to use
I use Sync frequently as I travel with work on a weekly basis and it’s great having new media automatically added at the weekends. However, I have a few suggestions that (for me at least) would make the process better;
  • create a ‘default’ for sync that is editable. For the vast majority of my TV shows, I want to sync 3 unwatched, high quality. I’d be happy to edit for any not ‘standard’ to me
  • create an export / import function for syncing to save me having to manually add 30+ TV shows every time there’s a bug (or fix) that requires you to wipe your synced data & start again
  • allow the Sync listed to be sorted alphabetically (TV Shows & Movies separately) so we can see what’s already been added
  • don’t allow the same TV Show / Movie to be added twice (when going through web or browsing on tablet, you can add as many instances of a TV show that you like)
  • if adding a single TV episode, check to see if the series has already been added and follow the rules for that
    prompt somehow for deleting watched movies (unless I’m missing something, watched movies don’t get deleted and you have to go into the sync list and de-select
  • lastly (and not a sync request), please show the clock / time when pausing playback
