[Feature Request] [Mobile Client] Modifiable sync queue
Hello all,
I’m often travelling and sometime I don’t have the time to sync everything I want.
I wish I could change the order in which the files are being sync instead of having them chronologically sorted. (first selected at the time is to be synced first forever).
The only way to change the priority is to remove the sync (removing the file associated) and resync.
Thanks :slight_smile:
