[Feature Request] Only require "secure connections" for remote connections
Hi Plex Peeps,
I have always used the “Secure connections: Required” feature as I share my library remotely with family and friends. This hasn’t been an issue as i would just simply use secure connections across my home network… until now.
I am now using plex to stream 4k content within my home network. 4k bit rate is so high it doesn’t play nice with the LG TV’s 100Mbps network port so i have switched to using WiFi. The 4k content also doesn’t play nice with “Secure connections”, i guess due to the additional encryption overhead. I see much higher bandwidth spikes on the plex server when non-secure connections are being used for 4k content.
I am currently using “Secure connections: Preferred” to get around this issue… but now i have to worry about family and friends disabling the ‘secure connection’ feature or using a player that doesn’t support ‘secure connections’ (ie PS3 or Xbox360).
I know there are a lot more important plex features/fixes needed, just thought i would throw this out there. Maybe it wont’ be too much additional work as the Plex server already understands local vs remote connections for the bandwidth limiting feature.
Can‘t you put the LAN ip range in the “does not need auth” exception list?
Thanks for the suggestion, just tried didn’t make any difference to the secure requirement.
