Feature Request: Option to Automatically switch to offline mode
Sometimes it’s not clear as to what content is available locally on the device, whereas offline mode makes it very obvious. However, if you switch into Offline Mode, and forget to switch back when you have a good wifi connection, Sync doesn’t update.
So it would be great to have an option to automatically switch to ‘offline mode’ whenever there’s no wifi connection (or even based on SSID). :slight_smile:
I hadn’t seen it. The structure isn’t as clear in Discourse as it was in the old forums…
