[Feature Request] "Pin Tidal" Playlists to Plexamp Recent Plays
Team,
The “Recent Plays” section of Plexamp is brilliant! Taking it one step further would be to enable us to “pin” playlists from Tidal to this section in our own server. I have many playlists in Tidal that I’d love to play in Plexamp (on my server side), and keeping many “most-listened” playlists would be great, so they don’t eventually move to the bottom and then out.
<Even better request would be to show all Tidal playlists in the Plexamp (own own server) section so we would toggle less often to the Tidal server side.>
Thank you for your consideration!
Love Plexamp!!!
Hello!
I think have a similar suggestion. I think perhaps having a way to search Tidal’s playlist based on their tags (Genre/Moods, Activities & Events, etc) would be an effective way to implement this. I know the search function in Plexamp does list Tidal Playlists that matches the search term, however, if there was a way to search using Tidal’s own tags it could allow simpler search for Tidal content, should one decide that they want to stream some of Tidal’s Playlists while using Plexamp.
Not sure if this is something that can be added without too much messing about. For now, I can just swap over to the Tidal App when I want Tidal exclusively. I guess I’m asking so that I don’t have to keep switching apps. It also has the benefit of keeping that Sweet Fade! :stuck_out_tongue:
Cheers team, great work indeed!
