[Feature Request] Remember Position in Playlist
I like to take all the episodes from a couple of different shows I watch and combine them into a playlist, usually using the shuffle feature to make my own customized random TV channel of sorts. However, recently I wanted to combine two new shows I have not watched at all into a playlist and watch in sequential order. I ran into the issue where every time I start the playlist, it starts from the beginning instead of picking up where I left off.
I propose a feature that keeps track of the last thing watched in a playlist and returns to it when you play the list again. Ideally it would return to where you left off on the episode as well. You should be able to override by going to an element directly in the playlist or by using the shuffle feature at playlist level.
duplicate feature request
closing
please respect the rules for this subforum
