[feature request] Remove from Continue Watching to move items to Rediscover hub
Hi Team,
Is there a way to for android tv plex app, on the home screen to have the option when removing a tv show from the continue watching row to be placed on the rediscover row for tv show library?
Probably best to request that via a feature request. AFAIK it’s only available on the webui via a browser.
The option to remove items from Continue Watching should not be limited to the web app (it’s available on iOS; IIRC it should also be available on Android using a long press to access the item’s context menu).
However those aren’t moved to another hub. So we can easily make this a feature suggestion. Though from what I remember, the Rediscover hub is more about stuff you haven’t been watching for quite some time. There’s no „lifecycle“ for items „expiring“ one hub to transfer to the „next hub“
Thank you both. Looks like I am already in feature suggestions lol. The reasoning for removing from continue watching row is because I like to mark some shows episode 1 played as a reminder to watch them later. Similar to how rediscover hub is being populated.
