Feature Request - Subtitle Language Filter
I'd like to have a new feature in Plex - to filter movies by subtitle language.
I saw a couple of feature request just like that and I'm sure it will be beneficial for both you, and the people who are using your software.
It would be event greater if you could make an easy way to create custom filters like an add-on.
Thank you.
After 3 years of waiting finally the filter by language and subtitle language has been implemented. Thank you.
